Make: Nissan
Model: Silvia K's
Milage: 140,***
Transmission: Manual (close ratio s14 box - has had manual conversion)
Colour: black
Complied? Yes
RWC supplied? N/A
Currently registered? Yes. Rego runs out 9/9/08. If not sold by then i will re-register.
Price: I bought for $8500 with 12 months rego. But am open to offers
Contact: Nick - 0410-803-199 - [email protected] / [email protected] (during business hours)
Comments / Modifications:
Hey guys,
Well i've had this car 12 months, and hardly any of you have ever seen my car lol.
But its time for me to let it go. I just can't afford to keep it. its due for a service which i can't afford, and it does have a lot of issues that would need to be fixed up. I rushed into buying this vehicle, and bought it for $8500 with 12 months rego. Rego is coming up in september so if it doesn't sell by that date, rego will be put on it.
This was bought off a forum member on SAU. I will not disclose his user name as i do not want to slander him. But he is extremely dishonest and regret buying this vehicle.
**1991 s13 silvia k's sr20det (Non-HiCas + Non ABS)**
-Modified close ratio 5speed s14 gearbox.
-140XXX klms.
-400hp fuel pump
-Sard adjustable fuel pressure reg (rising rate)
-Custom oil catch can
-Rubber vaccume hoses replaced with simota Silicone hoses
-Annodised oil temp sensor mounting block
-new oil hoses and annodised oil fiitings on tubo(new/all speedflow fittings used)
-Top mounted T3 Bush Bearing turbo - Also found out (after buying the car) that this is also a cheap shit EBAY turbo
-Stainles steel top mount tuned length exhaust manifold - This is an EBAY Manifold - which i was informed of AFTER buying the vehicle - It has been rewelded by Castle Hill Exhaust and they informed me that it was cheap shit
-38mm external waste gate with screamer pipe
-3"cat back exhaust
- Non Turbo front bar (no longer has vent for side mount)
-Alluminium radiator overflow tank
-Front mount intercooler kit fitted
-Battery relocated to the boot
-Earth kit fitted to engine
-32mm rear sway bar fitted
-BLITZ boost pressure,exhaust temp,oil temp and water temp gauges with memmory recall(fitted - some of these guages aren't hooked up tho)
-GReddy boost gauge with adjustable warning and memory recall
-FIELD digital fuel adjuster - Its there - not sure how to use it tho
-S14 ignition coils fitted
-DNA motorsport boost control valve (not fitted)
-Electric thermofans fitted
-Kenwood Double-din headunit with mini disc - not fitted, but can include if you want - vehicle currently has no sound system
-JBL 4x6" front speaker 200watts each
--Fusion wiring fitted
-New battery (heavy duty bosch)
-Interior retrimmer in creame & Black with black stitch
-Momo steering wheel
-Momo boss kit
-Apexi turbo timer
-New good year eagle NTC5 tyres fitted- 4months old.
-series 1 s13 silvia headlights fitted
-Serviced every 5000kms using genuine nissan parts
-Exedy extra heavy duty clutch with 1200kg pressure plate
-Power windows
-Power mirrors
-Climate control
-Central locking
-Power antenna
-Tinted windows
PROBLEMS:
-Oil leak from gearbox tail shaft seal - Can include NEW genuine seal
-Small dent behind drivers door
-Paint chips on rear bar
-Damaged rear quarter due to being hit in a car park (has been sprayed over)
-Various small dings and scratches
-Bonnet needs respray
- There is some rust starting to appear near boot
- Windscreen/door seals do look a bit ratty, however do not leak.
- BARE wires in engine bay. There's alot of shotty wiring. Also done by previous owner
- Reverse lights not hooked up after manual conversion
**NOTE** - Vehicle was in minor accident. Has been fully repaired by Western Smash Repairs. Due to the accident, front bar and LH front quarter panel have been replaced/resprayed.
Thanks
Nick
Images:
https://www.sau.com.au/forums/topic/228983-91-s13-ks-sr20det/
hey there, would u be intrested in a swap with a pulsar n14 sss 92, with full custom red interior, bucket seats, lsd, g4 adjustable suspension, sr20, k&n pod, exhuast,
17inch black gestalt rims, rego, tints, big system etc? pm me if ur keen, baby blue coulur, wingless
  • 3 weeks later...
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
    • Strength. And on the early RB26, full engagement of the pump drive.
