Hoodie Orders!
rad100
 Share
  • Replies 665
Posted Images
ok guys a real update now. Going with all Gildan hoodies and zip ups, so a few things have to be clarified.
Pete and Kellie - please advise me of which of these sizes will suit your respective children (they are childresn S, M, L and XL):
Measurement (centimeters)
Width Length
Small 38.08 45.72
Medium 43.52 53.34
Large 48.96 60.96
X-Large 51.68 66.04
Responses ASAP please guys.
Thanks
Damo, as per phone conversation, I'm guessing the young fella will be a Medium......I'm hoping that's the equivalent to a size 10.
Those above sizes are weird.....I'm assuming that 43.52cm is the measurement across the chest or back, not around the chest (based on that length).
So go for a Medium unless you find out something different about the new sizing.
hey lauren just freaked out a little haha
she was pissed before ther was no pink in colour choice, so now shes happy....
but yeah can u make it light pink please :P
ta
ok so pink for Lauren, Pink For Vu (or Mel :P), medium for Daniel, Small for Locky, so just waiting on lin33r.
Width Length
Small 38.08 45.72
Medium 43.52 53.34
Large 48.96 60.96
X-Large 51.68 66.04
Lin33r, Vu and Kye, light blue is not available in the gildan range, so would you like to change to royal blue? Or you can choose another colour, found below:
light pink, white, navy, black, red, royal, and sport grey (light grey). the colour chart is here, please look under the "FLEECE - 18600 range" http://superioraw.com.au/images/colourguid...urguide2008.jpg
Thanks
CRAP! is it just me or are these szes TOTALLY different???? i'd probably be an XXL or XXXL in the new brand of tops, are we able to change that???
18600 S
51cm x 69cm M
56cm x 71cm L
61cm x 74cm XL
66cm x 76cm 2XL
71cm x 79cm 3XL
76cm x 81cm
All WxL and slightly different to the sizes you listed earlier for gildan...
LOL I'm sure (well hope so anyway) that when the hoodies are done either ither or booth Adrian or Damo will let us know! So far the organisational skills haven't let us down so i don't see the need for them to start now. :D:banana:
 Share
    • Hi all,   I have bought a JDM R35 at auction in Japan.  This is my second JDM GTR after owning one back in 2009.  I have made a couple of videos that may interest some forum members.  One is collecting the GTR from the compliance shop (and seeing it for the first time) and another on the process of buying and importing a car from Japan.  I'm new to this and would appreciate your thoughts, as well as a subscribe!
    • Sorry, AFM.    Will edit original post
    • Oh, yeah, no arguing that the duty cycle is different. And a circuit car will go to those speeds for more distance and longer times. But, I suspect that if a tailshaft has a harmonic problem, that it would cause damage and shit itself maybe even on the first pass. A second or two of running at the resonant/harmonic problem speed is already a couple hundred revolutions.
    • Shaft speed would be the same, however it's how long they hold it there for and repeated conditions. FWIW half way down the main straight at SMSP I'm bouncing off 4th with a 8600RPM limiter. That shaft would be spinning at 8600RPM for a few seconds before I need to smash the brakes, by T2 it's getting close to that speed again. Now a drag car/roll race car would see that shaft speed for a 1 to 2 secs then they would coast, hit the brakes and that's it.
    • With same diff ratio, tyre diameter and road speed, the tailshaft rpm is the same regardless of the gearbag's ratio. Given that very quick drag cars are probably doing similar road speeds to the fastest circuit cars (circa 300 km/h), and there will be many of either category that can't go that fast and so you'd have inummerable matchups between drag and circuit car speeds at smaller numbers, and given that they are probably using rather similar tyre diameters and probably using similar diff ratios, and...where any of those numbers were different they could quite easily be in opposite directions thus cancelling out.... I think you'd find that there'd be more similarity than difference in tailshaft speed between these two use cases, no?
