  • Replies 665
Posted Images
hahah.... a fire! original! lol...
could have said a twister passed through
Reminds me of Top Gear and they had a fire.....and they blamed Fifth Gear...
Maybe the place where we were gonna get the hoodies from originally got jealous? :)
...Well in Damo's little world anyways!
Edited by fullyhyperlite
ok guys a real update now. Going with all Gildan hoodies and zip ups, so a few things have to be clarified.
Pete and Kellie - please advise me of which of these sizes will suit your respective children (they are childresn S, M, L and XL):
Measurement (centimeters)
Width Length
Small 38.08 45.72
Medium 43.52 53.34
Large 48.96 60.96
X-Large 51.68 66.04
Lin33r, Vu and Kye, light blue is not available in the gildan range, so would you like to change to royal blue? Or you can choose another colour, found below:
light pink, white, navy, black, red, royal, and sport grey (light grey). the colour chart is here, please look under the "FLEECE - 18600 range" http://superioraw.com.au/images/colourguid...urguide2008.jpg
Responses ASAP please guys.
Thanks
Bad news guys, the outlet where we are getting the hoodies done has had a fire overnight, i found out by phone call this morning. I will look at refunding everyone's money as soon as i can. Thanks guys :ermm:
Just kidding :P
:thumbsup:
I hope you die of a death overdose...
Maybe the place where we were gonna get the hoodies from originally got jealous? :thumbsup:
nah it was those shifty blokes from NS!
um, no, only those who ordered light blue
Guest
    • Given by the sheer number of questions about offset, absolutely not. If you had the information formatted this way: Space from R34 GTT hub to outer arch = 100mm Space from R34 GTT inner hub to nearest suspension arm = 90mm. (making this up) Buying a wheel that was advertised as Enkei RPZ5 Diameter 18in Width 9 Distance to arch = 84mm Distance to suspension arm = 76mm 100% of people would know instantly if it fits. They would absolutely also know instantly how close it fits too, and no questions would need to be asked. You would know you would have 16mm from the guard and 14mm from the suspension arm.
    • Ah ok, for example for the apexi ecu I heard that it's pretty limited with the information it can give you. Also not sure why Nissan used the consult port over the obd2, what the idea there was.
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
    • How do you go about diagnosing ecu's that don't have data logging, is it more experience at that point and just trying out things that you think will fix the issue?
    • Stock O2 are basically useless beyond anything at stoich. Any misfire will also be seen as lean. The stock O2 also read a collective exhaust gas volume, not each cylinder. Sputtering and missing means not each cycle is firing, and some are. Which means even if rich, as shit, on cylinders as they miss, they'll read lean, but the cylinders that did fire will read rich, and combined, well, they can read anything from rich to lean.   Start with the basics before even going looking at sensor values.   Edit: I say the above, and that's coming from the guy with a few thousand dollars worth of scan tools sitting right beside me right now that I use frequently for my job.
