  • Replies 665
Posted Images
with all the people stressing out over their hoodie in this thread I think an SAU walking stressball group buy should be next before the next hoodies orders :domokun::domokun::devil:
HAHA I would buy that!! :domokun: Do they come in other colours? How much can we get them for in a group buy? :cool:
black probably be best and it was something like $7-$9 each with walking legs... and about $4-$5 each for ones without walking legs...
hmmm and is that with or wihout the SAU logo? I guess the legs makes it ideal as a desk ornament :domokun: Or dash mounted...for times of frustration in peak time traffic!
Edited by N-DAWG
Lets not forget the SAU Stress Ball Launcher!!
http://www.tshirtgun.com/
Each cannon also comes standard with 2 vinyl logos at no additional charge, and custom graphics and designs are available at an additional charge.
ok so the hoodie thread, i have signed and faxed the final proof, printing is due to start today/monday!
Well done guys! Take our impatience as a sign of a job well done :D We just wanna be proud to be SAU
Guest
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
