update for payments....
drd-00f...PAID
Monkeyboy...PAID
bezender...PAID
gtr-r32...PAID
typevu...PAID
musky...PAID
sambo33...PAID
ndawg...PAID
cronic...PAID
r32skyline93...PAID
hi2u...PAID
thanks for the quick payments and thanks for following the instructions!! makes it easy to identify!!! :thumbsup:
thankyou again
  • Replies 665
Posted Images
If your picking up hoodies, we will arrange a meet at Vili's after we recieve the hoodies so you can pick them up. Thanks for everyone's interest and co-operation, means we will get the hoodies ASAP rather than sorting through unpaid orders etc.
Thanks Guys
hoodie/jacket: Hoodie
username/real name: Nightcrawler
name in caps or not: Cap N, rest lowercase - exactly as above
colour: Black
how many: 1
I will transfer the money tonight reference: Nightcrawler
Cheers, Andrew
Hmmmm im considering getting one...but i dont actually have a skyline haha, i just take photos :D.
but then again i got a free nissansilvia.com hoodie on the megacruise and i wear it non stop and i dont have a silvia hahaha
Hmmmm... :worship:
Nisskid, unfortunately as its a group buy, the jumpers get made once everyone pays. It seems like its a bit of a success, so there will more than likely be another group buy in a few weeks!
ahk, mm tempting, might have to jump on the next one then, see what the funds are like, might be able to make this one.
Guest
    • Next pic will probably bring back Charlie's PTSD So yes, pump is back out. I hooked the fuel return up to a hose into a container to flush out the first litre or 2, jumped the Fuel Pump relay and.......nothing.... Turns out the pump I had pulled out, checked, cleaned everything....was dead.  I hadn't actually hooked 12v to it to check it worked before I put it back in. Anyway...Neil had kept the old pump which still worked, so I just swapped it back in. All good, flushed the lines out, ready to start
    • OK....so something that works like it said on the tin! Fitting the pressure feed into the car was an absolute PITA because the oil filter is in the standard location and then there is a fitting to run to the oil cooler. On the other side between the filter and the steering box is the standard oil pressure sender (not working for some reason, something to check) and 2 tapped 1/8 BSP threads for the oil temp and pressure gauges. Unfortunately it is really tight in there and it took a hours of stuffing around to get a t fitting to connect the priming pump and retain the gauge sender.  Also, the Aeroflow sump has some massive drain plug (needs a 32mm spanner) so I couldn't use the regular fitting there either. In any case....once it was all hooked up, like magic priming.mp4 15 sec, 3 bar of oil pressure. Left it running a couple of minutes to push through everything, looked good
    • Yeah the latest style kit has been trouble free, I've done a fair few klm on it including pushing a bit on low fuel and it hasn't been surging (that's not an endorsement for race use, I haven't tried that low, or that hard cornering!). For street use it has been a good thing, handles the high current OK, only real issue is it is not cheap
    • So, how do you feel about the Frenchys surge tank setup @Duncan? Have you had a chance to try it out more? The sketchy wiring in my fuel pump setup has decided to melt and die and I'm looking for a solid replacement now. My fuel hat is toast so the Frenchys kits providing it all look promising.
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
