S,M,L,XL are kids sizes in the jackets, unfortunately the hoodies start at mens small.
Failing that option, i guess you could get measured up and use the measurements under the sizes on the first page! :(
Thanks for that Damo, I forgot that you had the actual measurements on the 1st page....so here goes:
hoodie/jacket:......................hoodie
username/real name:............SLED
name in caps or not:..............caps as above
colour:..................................black
how many:............................1
I can give you guys cash at Villis or EFT tonight..........whichever you prefer
  • Replies 665
Posted Images
Here's order number 2 guys:
hoodie/jacket:......................jacket
username/real name:............Daniel
name in caps or not:..............1st letter caps....not the rest "as above"
I can give you the cash at Villis for this as well.
is it ok to change my order to this i dont want my name printed on it anymore.
hoodie/jacket:(Jacket)
username/real name: (leave it Blank)
name in caps or not: (leave it Blank)
colour: (Black)
how many: (1)
cheers
Allan
Hoodie/Jacket: Jacket
Username/Realname: Whatsisname
Name in CAPS or not: As per above - capital W the rest in lowercase
Colour: Black
How many: 1
Payment ($56.60 )via EFT, tonight.
Thanks.
last day to recieve payments 2morrow!!!orders will be put in monday!!! so dont bother bank transfering sat or sunday!!
CHEERS
hoodie/jacket: Hoodie
username/real name: 260tech
name in caps or not: Not
colour: black
how many: 1
EFT tonite.
PS: postage est $10 to 6432? Sending $64.20, let me know if this is wrong?
Cheers GW
Edited by 260tech
Guest
    • Hi Fred, Are you still on here, I'm looking for 4 of these rims?
    • Looking back, I’m pretty sure I over-torqued the magnetic drain plug because I was trying to fully crush the copper washer. In hindsight, I definitely should’ve used a torque wrench. Either way, I ended up switching to a regular drain plug so I don’t have to deal with this kind of issue again. Big thanks to everyone on the forum for your support—I actually talk about you guys to my friends and coworkers
    • Curious to why you're not getting Jesse to do the exhaust, seeing that he has just done 2 GTRs with Aes valves.
    • What extra parts are you thinking you'll need to run e85 compared to e30?
    • I'm not aware of e30 in Australia, but I'm pretty sure e85 is still around. You really want a setup with an ethanol sensor so you can run any mix of ethanol depending on what you can access. Fuel Check NSW app shows 14 site in sydney metro with e85. What are you adding, will you put in bigger turbs too? Apparently the wastegates are pretty small and can't bypass enough as you run more boost.  I'm sticking to 1.3 bar with 98 on the standard turbos with my tune on advice from the tuner, and boost drops significantly in the top end; apparently larger turbos with larger wastegates are needed to get anywhere meaningful from there.
