Soundstream 12" Sub, Amp And Cap
For Sale
Massive Bass setup.
Came with my S15 as it was a Soundstream Demo car, this is the equipment that Soundstream wanted to show off, Sounds amazing in the car, Taken out so the car can be used on the track and i have taken a stereo down-grade.
All in perfect working condition, no receipts, documentation or boxes were provided when i bought the car unfortunately, but i have linked the manuals with the items.
Although they work correctly the bottom of the sub has suffered some scratches where it reads T4-12 900WRMS and the amp has 2 scratches to the top right, doesn't affect the amazing sound quality though.
Location Brisbane/ Gold Coast
Sub:
Soundstream Tarantula T4-12
MANUAL: http://www.soundstream.com/manuals/2006/sbw/TARTNTULA-T4.pdf
Specs:
# RMS POWER (WATTS) : 900WRMS
# VOICE COIL DIAMETERS (INCHES) : 3.0
# MAGNET WEIGHT (Kg) : 5.68
# FREQ. RESPONSE (Hz) : 25 - 1.7k
# Fs (Hz) : 36.5
# Qes: 0.414
# Qms: 3.584
# Qts: 0.371
# Vas (Ft3) : 1.03/29.27 liters
# Xmax (INCHES) 0.63
# SPL (dB) : 89
# HOLE SIZE (INCHES) : 11.25
# WOOFER DEPTH (INCHES) : 6.1
# RECOMMENDED ENCLOSURE (Ft3) : Ported 2.2
# RECOMMENDED ENCLOSURE TYPE : Vented
# AEROPORT DIMENSIONS (INCHES): 4 x 7.5(1)
# Cast Aluminum Basket
# Dual 4-Layer, 1-ohm Voice Coils
# Cloth Laminated Paper Cone with MD6 coating
# Stone Gray Finish with Diamond Cut Edge
# Hi Arc, High Excursion Surround
# Chrome Plated Back-plate
# Low Carbon Top and Pole Piece
# Triple Stacked Magnet Structure
# Vented and Extended Pole Piece
# Black Progressive Roll CONEX Spider
# Woven Tinsel Leads
# Gold-Plated Binding Posts
# BAEISV Hybrid Voice Coil Former
# C- Lock Rubber Gasket
# Rubber Magnet Cover
# Wood Packing Crate with Chrome Appointments
Amp:
Soundstream EGA900D
MANUAL: http://www.soundstream.com/manuals/AMP/EGA900_1400_1700.pdf
Specs:
# 900 watts RMS x 1 chan. 1 ohm
# 450 watts RMS x 1 chan. 2 ohms
# 225 watts RMS x 1 chan. 4 ohms
# Class D Circuitry
# TST™ (Twin Stack Technology) 2 amplifiers to drive one voice coil effectively doubling the power
# Fully regulated, MOSFET power supply
# PWM circuitry
# High quality FR-4 circuit board
# Satellite Power Gain (remote gain control)
# Continuously variable 24dB low-pass crossover (50Hz to 150Hz)
# Continuously variable 24dB subsonic filter (50Hz to 150Hz)
# Variable 0 – 18dB subwoofer equalizer @ 40Hz
# Continuously variable phase alignment (0°- 180°)
# Tri-guard amplifier protection
# Intelligent Distress indicator (IDI)
# Platinum RCA input and output
# Platinum 1/0 gauge power inputs
# 1-ohm stable
# 5Hz – 250Hz frequency response
# >80dB S/N ratio
# 0.30% THD
# Dimensions 12.6" L X 2.2" H X 11" W
Capacitor:
Soundstream SC5C
MANUAL: http://www.soundstream.com/manuals/Capacitors/SC5C.pdf
Specs:
# 5.0 Farad Digital Hybrid Super Capacitor
# 25VDC Surge Rated
# PCB with Blue LED Display
# Charging Status Indicator
# 16 Status LED's
# Metal Mounting Bracket
# Extruded Aluminum Housing
# Chrome Die-cast end Caps
Enclosure:
# 18mm Think MDF Board
# 160mm High
# 450mm Deep
# 940mm Long
# Pre-cut 12" hole for the Sub.
# Came from an S15 Audio Demo Car, but would suit any sedan with that amount of floor area
# Has a Carpet cover with 2 Soundstream Tarantulas on it and Cap mounting area
# Easy shape to make work in any car with a bit more carpeting.
Photos of the actual goods:
Putting $700 on it initially but open to negotiation.
Located on the Northside of Brisbane, regularly on the Gold Coast if you wish to see it there
Postage would not be an option, very heavy professional gear
Call or SMS 0410101090
Email [email protected]
 Share
