Are you prepared for stronger springs ? At some point the cams will be too agressive for the springs to control so stronger ones are needed, however, for most street setups a mild cam is all that is needed. A bigger turbo will do ninety percent of the work. Look in the RB20 section for other setups as being the first to try something new is over rated.
Yes, I expect to use bigger springs. Most cam kits I've looked at have springs for cams over 9.15mm lift.
For example, if I use 260 in/ext cam with 10.5mm lift in my RB26, what difference is it going to make with a 260 in/ext with a 9.15mm lift cam? How does a larger lift cam affect that characteristics of a RB26, assuming all supporting mods are in place?
...i've been told that you should go as much lift as you can. Is that true?
but no-one has answered this bit of the question yet? what if anything is the disadvantage of running bigger (or much bigger) lift
When using high lift camshafts it's not only the valve float issue created by weak valve springs that you must consider.
You must make sure ,
you dont have coil bind issues at full lift,
you must have clearance between underside of retainer to valve stem seal and valve guide,
you must have enough piston to vavle clearance.
if using larger valves, with big lift,high duration camshafts make sure on overlap the inlet and exhaust valves dont touch each other.
Lift is part of the equation,
Duration is where you need to do your home work.
Duration is what will be one of the most important need to know specs of choosing the right camshaft for your combination.
The higher the duration the higher in the rpm range you will make power and the harder you will have to rev the engine.
Lobe seperation is another critical issue.
The closer the lobe seperation and the larger the duration the more valve overlap you will experience.
Valve overlap is unavoidable.
Reducing this in a turbocharged or supercharged application isnt.
Its called correct camshaft selection or can be altered (reduced) through variable timing gears.
Large duration camshafts also suffer from more valve reversion on overlap.
Creating pulses back through the inlet side.
Not so much a problem on a GTR with 6 throttle blades as there is not really an inlet manifold as such to have these pulsations effect anything.
MAF sensor tuning can be a little trickier on FC with big duration camshafts,as far as idle and light throttle cruise is concerned,on engines with 1 throttle blade.
I tune engines using MAP or MAP THROTTLE if GTR.
ECU of choice Autronic.
I'm still in the dark regarding the benifit of extra lift. With were i'm at with my engine build, putting in higher lift cams isn't a costly exercise. I just want to know what it will do to the charateristics of the engine...?
More lift = more air into the engine and more exhaust out.
Engines are air pumps.
The more oxygen you can get in, and mixed with the correct amount of fuel, the more horsepower you will make.
Simple as that.
It's duration that has the biggest effect on your engines charactoristics.
You must establish what you want to do with your car before choosing camshafts.
Drag racing, Drift,Circuit Racing, Street/Strip etc.
Duration is the key word here.
EG: 220deg duration @ 0.050 is a small camshaft that would work well in street applications.
Useable power range normally 2500-3000 rpm to 6000 rpm.
300deg duration @ 0.050 is a cranky piece of gear, application Drag Racing.
Useable power range normally 4000 - 5000 rpm to 9000 rpm.
Above mentioned examples are NOT exact figures but are stated to give you an idea.
You can have a camshaft/s with 9.5mm of lift and 220 deg duration for street.
You can have a more aggresive camshaft/s ground with 9.5mm lift and 260 deg duration,this camshaft will make more horsepower but at a higher rpm.
Camshaft selection also comes back to engine hardware.
11 mm lift 300 deg duration on an engine with stock internals and standard turbo charger is pointless.
What do you want to do with your car,what is done to your engine.
I have made 625 hp @ the wheels with a customers car using only Tomie Pon Cams, but had the engine and turbo charger to support such a figure.
I know that if i want more horsepower with that combination i need more lift and duration and another set of springs.
However this is a street car and the owner dosnt want to sacrifice drivability. :P
So lift increase with no duration change = small/ marginal performance gain.
Lift increase with duration increase = more gain in power.
Edited by supercharged88
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
