Hi,
I decided to pull my pod off and clean it a little then thought i should take my AFM and clean that a little too. I unplugged the cable on the side to remove the meter and put it all back together, then my car wouldnt start! It ignites and for a about a second it runs then just dies. My sensor sw/check on the power fc says the AFM has no voltage, sometimes it increases by .01 v but nothing more.
So I pulled it apart checked it all and put it back together, no difference.
Again, put the plug upside down and no difference.
I really hope i haven't fried my AFM!
Woops double post sorry!
https://www.sau.com.au/forums/topic/229070-standard-33-afm-has-no-voltage/
Seeing as the signal loss from the AFM occurred when you ... removed the plug, I'd assume the loom is damaged around the plug area. Search for pin designations, and test for good ground, power etc.
Get someone to wiggle the plug while you check the hand controller, go from there.
What did you clean the AFM hot wire with?
EDIT: F5 before clicking submit, when will i learn.
Edited by GeeTR
I didn't actually clean the entire AFM, I brushed the intake side off. The plug is a weird looking one, it sorta sits and you screw it in and there are 3 pins the come from the cable to the AFM.
Ok played around with a friend and determined that the ecu is still receiving voltage from touching it with fingers (human electricity????).
Fiddled some more and fitted the plug in the AFM and received some voltage! Only .25 volts though and this wasn't enough to get the engine running.
I reckon the pins on the plug have bent or the AFM receiver isn't conducting well.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
