Contact: Sam
Number: 0417 958 454
**Pickup Only**
ALL ENQUIRIES, PLEASE PHONE ME, I AM NOT CONTACTABLE ON THESE FORUMS
Item: Apexi Power FC
Price: $1000
Condition: Used for 5000km approx. Tuned for S2 R33, full exhaust, FMIC, Bosch 044 fuel pump, std injectors with adjustable fuel pressure reg, High flow turbo running 18psi - 220kw, standard motor.
Item: Z32 AFM with plug
Price: $220
Item: R33 5spd gearbox with almost worn 5 puck ceramic exceedy clutch, and tail shaft(R33)
Price: $1500 ono
Condition: Done 108,000km, excellent condition
Item: R33 S2 motor, Does NOT come with turbo, fuel rail, injectors or coil packs. Does include head (perfect condition) with adjustable exhaust cam gear. Includes flywheel.
Price: $350 ono
Condition: Block has slight damage near water pump(as seen in pics), sump is bent, otherwise in excelent condition.
Item: R33 s2 diff
Price: $300
Condition: excelent
Item: R33 brakes (calipers, rotors, entire assembly) front+rear
Price: $500
Condition: excelent
Item: White R33 rear boot lid with drift style rear spoiler including hinges and struts
Price: $350
Condition: Perfect condition
Item: White original R33 S2 rear wing
Price: $50
Condition: excellent
Item: R33 tail lights
Price: $100 each
Condition: perfect, working condition
Item: R33 GT-R rear sway bar
Price: $50
Condition: excellent condition
Item: R33 S2 interior (front seats, rear seats, rear trims, scuff plates)
Price: $350
Condition: perfect, no marks, no holes, as new
Item: R33 floor mats
Price: $100
Item: R33 split dump and front pipe (1pce) - stainless
Price: $130
Condition: Slight damage on wastegate pipe - can be repaired
Item: Drivers door - white (not including mirror). Includes glass, hinges electric window motor etc.
Price: $250
Condition: very small damage to door trim. Paintwork very good condition.
Item: Passenger door - white (not including mirror) otherwise complete
Price: $300
Condition: Excellent to perfect condition
Item: mirrors
Price: $100 each
Condition: Excellent condition
Item: Rear insert (goes between lights / under bootlid - reads skyline), white S2
Price: $50
Item: White R33 fuel cap
Price: $50
Item: Electric antenna
Price: $50
Item: R33 white rear bar (custom modified to make number plate area neater for aus plates)
Price: $200
Condition: Very good
Item: Inlet pipe with factory blow off valve fitted
Price: $50
Item: Automer guage (boost with cup and mounting bracket)
Price: $50 ono
Item: Automer guage (oil pressure)
Price: $30 ono
Condition: new in box
Item: drift Catch can
Price: $20
Condition: scratched, but perfect working order
Item: Blitz pod filter
Price: $150
Condition: very good condition
more pics to follow
Edited by gucc_33
https://www.sau.com.au/forums/topic/229077-wrecking-r33-gtst/
ill do tail lights for 150 and i am willing to split up the brakes and power fc comes with hand controler. please call do not have the net and have to rely on a friend so is hard for me to be on line. cheers
I got a S2 rear wing off this guy today. He is a very genuine and friendly bloke. I went and picked it up today from Moorabbin. As mentioned above, for a fast reply please sms or call him for info on the stuff . I don't think he is on this site to often.
Thanks again Sam and all the best selling the rest of the parts.
Also for sale:
Item Adjustable exhaust Cam gear
Price $50
Condition Excellent, like new
Please note, I can't always get on the net, I need to use my neighbours computer to post, please call the number in the first post if you are serious about buying something.
Cheers,
Sam
  • 8 months later...
  • 3 weeks later...
    • Some sense has prevailed! What kind of idiot spends money on intake, heads, and cams for a N/A motor in 2025? Lol. What maroons. Source:I am King Maroon.
    • So, cams are not getting installed......yet  Had a good chat with MX5 Mania about intakes, they recommend not to get ITB's, they recommend a plenum style for the NC So, one of these puppies is being ordered, with a larger TB to suit, when it arrives from the US the car will go in for the cams and intake I'm also getting a fancy rear box bit for the air filter box which will suit the new TB size
    • Clamp meter is pointless. Unless you're trying to keep average current under a set value for some weird reason (maybe you undersized your wiring?), then you'll get no useful info. What you're really trying to target is the flow of fuel coming back to the tank. You want some, but not a lot. You also want to make sure fuel pressure remains stable.   So, fuel pressure gauge, and fuel flow gauge. Set it up from that.
    • Aside from the fact it is likely fuel related if it is black, the symptoms otherwise sound like worn valve stem seals. Oil gets past the worn seals when the engine is off and burns when the engine starts. If it happens on deceleration while driving (puffs of white smoke) that is another valve stem seal symptom because oil gets sucked form the head into the combustion chamber under vacuum with the throttle closed. They can be replaced in the car if you have some way to keep the valves closed while working (eg compressed air into cylinders) but is much easier with head off.
    • Alright, fair enough. Expected as much. Possibly, yes. However the kit is apparently not including every single hose and it is out of stock too.
