Hey Guys
To Fit: any car
Contact: Daniel 0401765015 ( text me yeah cant pick up at work)
Item:2 sets Focal K2 Power 165 KP
Age:NEW
Condition:Brand new in Box
Price:$420 negotiable/set
Comments:decided to install my Hertz ones instead
Item: 2 sets Alpine SCS-1756 Components / tweeters
Age:3 yrs
Condition:1 set Brand new Condition, second set has dent in tweeter grill else looks brand new
Price:100/set
Comments:from previous previous install just sitting around
Item:Pioneer A6981S 420W 6x9's
Age:2 yrs
Price:100
Comments:bought initially for skyline couldent fit
Item: Rainbow SLX-265 splits components, tweeters, and crossovers
Age: 6 months
Condition: Brand New in Box
Price:$320 set
Comments:have 1 set installed and put the hertz into front, dont need second rainbow welcome to come listen too
Item:MB QUART DSD-2165 splits components, tweeters, and crossovers
Age: 3 yrs ( used for 6 mths then in storage)
Condition:Used, but Mint condition, one tweeter grill is dented
Price:$100
Comments:previous sound system, just sitting here
Item:MB QUART DSE-2165 splits components, tweeters, and crossovers
Age: 1 yr
Condition:Used, but Mint New condition, one tweeter grill quite dented.
Price:$140 set
Now before you guys ask why one tweeter grill is dented from most of my sets of speakers it is because the drivers side door in my old civic, where the tweeter sat used to touch the gauge holder when closing the door, so the tweeter always would get dented in the front right. But for all intensive purposes the sound is fine.
Any one who has a problem with the tweeter dented, I also have a Perfect set of Clarion tweeters you are welcome to take as replacements, they are awesome.
Mistake on the MB QUART models
they are
MB QUART DSD-216
* High-quality components and a precision crossover network
* Titanium ¾ (19mm) dome tweeters with neodymium magnets
* Polypropylene 6½ (160mm) woofer cones with butyl rubber surrounds
* Precision upgraded crossover networks with audio-intensive technologies
* Crossover Freq: 4500Hz Hz
* Crossover Slope: 12 dB/octave (DXD 216 Xover Crossover for DSD216)
* Nominal Size: 6-1/2" (165mm) RMS Power Handling: 50w
* per speaker Peak Power Handling: 120w
* per speaker Frequency Response: 40 Hz - 32000 Hz
* Impedance: 4ohm Sensitivity: 89dB
And MB QUART DSE-216
Impedance: 4 Ohms
Frequency Response: 40 32.000
Sensitivity: 2,5dB
Power Range: 50-120 Watts
Crossover Frequency: 5.200Hz
TITANIUM DOME
Titanium was initially developed for the aerospace industry because of its superior strength-to-weight-ratio. It is at the same time both very light and very strong. As a material for tweeter dome application, titanium is ideal only if properly engineered. MB Quart has nearly perfected the use of titanium over the past 25 years. The new, smaller 13 mm Discus tweeter domes provide a smooth frequency response and extended bandwidth in a very small package.
POLYPROPYLENE CONES
The cones of the bass and mid-range drivers are made of a special mineral-based polypropylene. This material is far superior to a conventional paper cone. This applies to both its acoustical properties and its resistance to humidity, temperature fluctuations and UV radiation. The result is pure listening pleasure, year after year.
  • 1 month later...
  • 4 weeks later...
    • Welcome.  800hp should be a bit of weekend fun!
    • I'm going with "Just run two gates". Fix the problem conclusively. It's the only way you'd ever truly know, right?. This is all pretty much splitting hairs. Even the extreme example where it takes two whole seconds at 100kmh or something sounds monstrously dubious. And anyway, when you're punching the throttle when you 'need' this power, you aren't at 2800rpm in the wrong gear. Test it at 5600rpm in 3rd gear, when you're traction limited punching out of a sweeper. Much difference there when you account for traction?
    • And the full R32 GTR wiring diagrams are also freely available. Hmm.... there's supposed to be an auto replace that would have linked the thread. Here it is, manually
    • Ahh...should have been clearer ~ there's 2 ... SMJ = super multi junction (connector)...   ...this is connector 6 & 25 in above image -- body harness to engine loom (6) & body harness to main loom (25) Headlights go to front via connector 6 ; fuel gauge goes to tank sender via connector 25  ...like I say this is R33 diagrams, but at a pinch R34 won't be too far different. *IF* the two ground faults are related, this can be the only place where both wires converge (as one runs to the back, the other to the front)... ....thing is, you probably need to establish if the faults are related (unless you examine that area and find obvious chaffing on the looms there to body ground)....*IF* the fuel gauge is still broken (full needle deflection), I'd be headed for the boot, remove fuel sender wire, key on and measure the voltage there ~ it should be roughly 10volts. If that's ok, check sender to ground resistance...if this is a dead short to ground (and there's fuel in it), then sender has failed or something funky has happened to wiring in the tank. edit: ahh...rereading the thread, this is R32....above fuel sender test still valid tho'
    • I just changed the timing belt on my RB25DET NEO and wanted to get some opinions. I’ve been super cautious, did a lot of research, and took my time. I’ve driven the car, and it runs fine. After warming it up, I revved it to 8000 RPM a few times—no issues, everything held up.   After the drive, I heard a noise that I think is either the clutch or possibly a tight accessory belt. It’s not constant, just comes and goes.   I took the timing cover off to double-check everything:   Belt is on properly, Tensioner is tight, Did the 90-degree twist test—belt isn’t too tight or too loose.     What still worries me is that I noticed the belt seems to sit a little toward the front edge of the gears, especially on the idler pulley. It even looks like it’s slightly coming off the edge there. Is that normal?   My old belt (5 years old, ~3,000 miles) also showed a bit of wear on that same edge, so maybe it’s just how it sits? I’m probably overthinking this, but since it’s my first time doing this on a NEO and the engine is forged, I really don’t want to mess anything up.   Also, I’m thinking of swapping to a clear front timing cover with the glass window. Would you recommend NITO or HPI? HPI looks reputable and their covers have 2.5mm thickness, but not sure if there’s a real difference between the two.   Any advice or reassurance would be much appreciated!
