Hi guys n gals,
Is there an easy way of changing the globe? Its in the weirdest position ever! Neither my mechanic and myself could get out hands in there to get the plug out. Is there an easier way of changing the globe without taking out the coolant tank, the windscreen washer tank and loosening the fuse box?
Thanx
https://www.sau.com.au/forums/topic/229098-changing-an-r33-rhs-park-globe/
there's no easy way
take the mounting bolts out of the washer tank, and move it as far to the side as you can.
grab a pair of long nose pliers ( i think i used angled ones) and get ready to strip some skin off your hand.
you can reach the bulb holder with the pliers and twist and pull it out. it takes a while, but saves you taking out the fuse box and overflow tank.
