Hi Guys,
Okay, found out that brand new they are 4.05mm each!
If they are 2.75mm each now, would they suit a rebuild OR could i just put them in as is?
Potentially how long could this clutch last for with this knowledge in hand? THanks.
no idea. you need to fine out what the actual thickness is of the friction material not the plate. you need to know the new thickness, and the replacement or minimum thickness.
even that knowledge still doesn't tell you if the intermediate plates are warped? or the diaphragm is shagged.
iv got one on my line. have had it now for 1.5 years been smashing it the entire time. prior owner in japan installed it so not sure how long it has left in it i would say about 20-30% more play. makes so much noise from the floating plate especially in low revs. but for drag racing and pounding the clutch it can take a beating for a long time. im getting rid of mine once it dies as the vibrating noise at low revs gets annoying after a while. lots of other options out there. i love the lightened flywheel that came with it though. revs up very quickly wants to sling shot off into the distance without even giving me warning.
From what you have said your clutch must not be fully engaging to be rattling around when your revs are low. If it is rattling abit when your idling at say a set of lights with your foot on the clutch that is normal but to be rattling when your foot is off the clutch and the clutch is engaged should mean something is wrong in my experience. I had an exedy twin plate and never rattled except when i pushed my foot on the clutch.
GTR-PWR. For that price i wold say your better off getting a brand new one. That way you know it will last a long time and everything about it will be new. Eliminates the chance of buying and finding out there is something wong with it like beer baron said. From memory they are only a few hundred more new but that was a couple of years ago.
yeh wouldnt say rattled when foot was off the clutch. but at low revs. it was very noisy. more like a heavy vibrating sound. i was actually not going to buy the car because i bit worried of the noise. but had a vehicle inspection and yeh was just the clutch. 1.5 years later still drives the same. highly recommended for heavy foot pounding though. great for drag racing.
No, not necessarily. My Supra's twin-plate (with lightened flywheel) is incredibly noisy at idle with my foot off the clutch (ie: with the car in neutral). In fact, it's a LOT noisier that way than when the pedal is fully depressed. I've had the car inspected and there's definitely nothing wrong with the clutch. Possibly it could be because you've only had a twin-plate with a sprung centre and anti-rattle clips, and maybe yours didn't have a lightened flywheel? That alone can be responsible for a lot of the noise. Mine is the HKS GD Clutch Pro which is the more racing oriented version, which means it doesn't have anti-rattle clips, it has an unsprung centre, and doesn't use the sequential plate engagement system that the Clutch Max uses. Under load, under 2000 rpm, it is INCREDIBLY loud. As in, maybe twice as loud as the car itself. So I think it's just down to the individual clutch/flywheel design?
I've ridden in a Skyline that had a more road oriented Exedy twin-plate with a sprung centre and lightened flywheel and it was considerably quieter than mine. I could only hear the rattle from inside the car (with the windows up) if the engine was at low revs under load, not at idle. It was incredibly easy to drive, too. Mine, however, is a bit of a bitch :sick:
    • Ok, can confirm.  if you use it like a normal human being in the real world, it works fine.  it only starts crossing wires if I keep using the fob over and over again in a very short period. So if I just chill the f**k out, it works 😂😂
    • Im about to run a e30 mix of e85 and 98ron but i read that australian fuels specifically 98ron doesnt contain ethanol so on the calculator when it says pump ethanol percentage do i just put 0 or is this statement even true? And if it is true i assume i dont need to test any 98ron pumps.
    • So... the fob I had for my Skyline always had this issue where the "Unlock" button worked with no issues but the "Lock" button did nothing (and I always had to lock with the key) I thought I'd try resetting and pairing the key to the car today to see if that fixes the issue. I did the standard steps to program a key but realised my central locking was doing its own thing from time to time. 1st time: The driver-side doors would not lock or unlock when using the fob. No issues with the key. I figured it was the right time to change the battery in the fob so decided to go get one. When I went to the shop all doors locked and unlocked with the fob (while it had the old battery 🙃)   2nd time: When I locked the car, it would lock itself and immediately unlock. If I unlocked it, it would unlock and immediately lock.   3rd time:  After a bit of cursing and praying, that weird bug stopped. But then the rear passenger door started being a pain. It wouldn't really follow what the fob was asking it to do. Sometimes even using the key would not do what I wanted. So I'd lock the car with the key and all doors would lock, but the rear passenger lock didn't do anything at all. And then after a few moments, it would work again.   Is there a fuse that I should be looking at? or, is this one of those things where the door card needs to come off and some unit needs to be replaced? It just seems to happen from time to time and if I give her some space and come back later, there are no issues  🤦‍♂️ Also, should I try to program the fob again to the car just to see if that solves it?
    • One would assume a turbo is somewhere in its future down the line given they slap turbos on pretty much everything that arrives
    • I’m guess it’ll end up with a turbo
