Hey guys
I am looking at getting new wheels for my R33 GTR and am thinking WORK Emotions in 18 x 10 + 18
Just wondering how they would sit on an R33 GTR, weather they will be sticking out of the guards or sit pretty flush, looking at having them stick out slightly if possible?
Had the same wheels on my HCR32 and they sat quiet nice, out of the guards but not familiar with R33 GTR offsets
Pictures would also help
Thanks
https://www.sau.com.au/forums/topic/229132-r33-gtr-offsets/
Best to keep same tyre/wheel widths front and rear from what I've read.
18x10 +18's would be ideal for a bit of track action, but Abu doesn't want that. Going by his previous ride's wheels, he wants tyre on guard action. :)
Bit hard to tell, but going by those pictures, you could probably fit some 10.5 0 offsets. :(
Just think about what we thought about your last set of wheel's specs. In theory, they were WAY too extreme, but in reality, PERFECT! Don't be scared to get something that seems too aggressive. :D
https://www.sau.com.au/forums/topic/229132-r33-gtr-offsets/#findComment-4032370
i was under the impression you shouldnt stagger sizes on GTRs....
Yeah your not supposed to lol
ah yes
I am thinking xd9 again in white but more thoughts to come
https://www.sau.com.au/forums/topic/229132-r33-gtr-offsets/#findComment-4032460
Having had 9" R34 GTR rims (+18 offset too) on a R33 GTSt that sit very flush with the guards, I imagine they would be ever so slightly inside the guards on a R33 GTR.
R34 GTR rims are 18x9" +30....... not sure where you got +18 from.
I run 18x10.5" +18 and they sit pretty much flush... if you want them to stick out you'd want something even wider/bigger offset. I had some 18x10.5" +12 which sat out just a tiny bit, and i didn't like that, so i sold them. Maybe that would suit you.
To get wheels sticking out slightly the same as the 18x10.5" +12 i had, you would need either -1 offset in a 9.5" wide, or +6 offset in a 10" wide rim. Keep in mind the front guards are a bit wider than the rear.....
Here is a pic of my car on 18x10.5" +18
http://ferni.net/photos/Cars/0802_Ferni_GT...30/target0.html
https://www.sau.com.au/forums/topic/229132-r33-gtr-offsets/#findComment-4033334
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
