HDI-SBC-D-EVOLUTION
ONLY $329.00 for MEMBERS
PLUS $20.00 Shipping Australia Wide.
HDi Super Boost Controller Type-D EVOLUTION
SBC-D-EVOLUTION
This boost controller has been designed for universal fitment to any turbocharged vehicle. The HDI-SBC-D-EVOLUTION provides the driver with precision boost and accurate display and measurement.
Product Features:
  • HDi Super Electronic Boost Controller with Dual in cabin adjustment
  • Closed loop boost regulation
  • Fast target boost locking
  • 120psi Pressure balanced solenoid
  • Micro Processor controlled
  • Rigid aluminum casing
  • HDi SBG-D Plug & Play Boost Gauge with Day & Night theme
  • Peak hold and recall function (with HDI-SEBS)
  • Dual read out both Digital & Analogue Display
  • Dual Measurement PSI & BAR
  • Full 270 Degrees sweep dial provides superb visibility
  • Advanced full electronic stepper motor drive
  • High Intense light emit diode back light for high visibility
  • Universal easy installation
Product Function:
The HDI-SBC-D-EVOLUTION uses a high precision temperature compensated pressure sensor providing the precision pressure reference for your turbo boost control function. By employing a unique closed loop boost regulating technique, the boost fluctuation is minimized once the desired boost level is reached. The anti lag program minimizes turbo spooling time so that you can have Fast, Sharp acceleration while maintaining your ideal regulated boost level. The HDi Super boost Gauge Type D (HDI-SBG-D) employs advanced stepper motor technology for accuracy and fast response. Our dual display design shows both BAR and PSI in analogue and digital format simultaneously. This provides the driver with easy and precise read out in the shortest possible time.
PLEASE NOTE:
Hybrid Development International Pty Ltd (HDi) is the official and legal owner of the TRADEMARKS, Hybrid and HDi Logos. HDi has been manufacturing Hybrid Performance Products since 1994.
HDi does all its own Design, Testing & Manufacturing (D.T.M). We are not associated with any other company nor do we source our parts through another company or make them in the same factory. You are dealing direct with the manufacturer and not a middleman. Since June 2007, we no longer have a sole distributor in Australia. This company had its dealership terminated due to hi jacking our trademarks and patents which is poor business conduct, this has been legally pursuant. We would also like to point out we have never stopped production or changed our name to release a new product. We have re-established our own operation in Seven Hills, Sydney, PH: 02 9620 7388
  • 6 months later...
  • 6 months later...
Is there any chance of just getting the boost gauge?
Hi,
Thanks for the enquiry. The gauge can be purchased separately. However, please note it will only work with our HDI-SBC-D(SE) boost controller. The gauge is $80 plus postage.
Thanks
    • I started with the above in my head too, and I might be reading / thinking about what they want wrong, which is why I complicated it a bit further. Purpose I'm seeing is for the corner indicator to be on with headlights, and then if the indicator turns on it can still flash. The relay part above I can see working as required, except in the case of headlight is on, and indicator is on. The change over relay you've wired in would get signal from the indicator, and as it flashes would give power to the globe from the indicator, but as it flashes off, power comes from the headlight, which would cause the indicator to be constantly on when headlight is on, even while indicator change over is flashing. That is unless we don't care if it flashes or not if the headlight is on? I guess that's an OP clarification.
    • HI, Ive got an r34 gtt sedan A/T. The instrument cluster went out and I replaced it with another A/T everything visually looks the same and all the gauges work now with the exception of the speedometer and odometer. The speedo will stay pinned at zero until I'm going about 55kmh and then it'll say Im going about 5kmh. my odometer seems to be tracking at about a 1/10 of what it should. If I go 1km it'll say I've only gone 0.01. Appreciate any and all help. Ive tried searching through the forums reddit and a local fb group. The only info I think I've found is that some cars didnt come equipped with TCS (mind is) and the clusters may be different between those? I've also installed a brand new VSS and no joy obviously. TIA.
    • what speedo healer did you use?
    • Certainly. It is probably broken under the wire style clamp. At least that one is easier to get at than the front one.   Sounds like it isn't a major leak, I'd start with backing off the the water feed and return banjos into the turbos half a turn then tightening properly. Hardlines can still crack over time, either in the tube (particularly when turbos are changed if the banjo is siezed in the the tube) or at the brazed joins between the lines and the banjo fittings. A coolant system pressure test will reveal all. BTW you'd be able to get a sump without exchange, it will just cost more as they will have to source another stock one for the next customer. If you want to address the sump a much better option is something like this https://www.hioctanedirect.com/hi-octane-racing-sump-extension-nissan-rb26 that you weld in locally (and add the oil return fittings at the same time)
    • Pretty sure you are thinking of the throwout bearing there (which you should change when you change your clutch), when they are worn they will get quieter if you put your foot on the clutch. An input shaft bearing is turning/noisy at all times.
