Hey Guys, recently my battery died because i left my lights on so i had to jump start it, so after ive jump started the battery ever since then ive had this problem with my power steering.
now i dont know if its got to do with the jump start or if it was just a coincidence, but my power steering is now screwed, it gets really hard at times to turn a corner.
When i turn a roundabout for example itll seize up and release, its mixed. So its not like its hard the whole way round, just split moments if im making sense. Now ive checked my reservoir and its full and doesnt seem to be leaking, and my p/s fuse seems to be fine, so any information you guys can give me would be much appreciated. :blush:
Cheers,
Steve.
https://www.sau.com.au/forums/topic/229184-power-steering-problem-r32/
the main reason for heavy steering is a leak somewhere. and considering the numerous little pieces of presumably old rubber between the diferent hard line sections scattered all over the car, including the ones back to the hicas..... ya probably leaking somwhere.
replacing old power steering lines has become a hobby of mine with my 32.... just about got them all.
probably a fault with the vehical speed sensor, maybe fried it when you jump started. as i understand it, when your at idle and not going anywhere a solinoid switches the powersteering pump into a low pump mode so it doesn't bog the engine down, once you start moving it swiches the pump to full. if you speed sensor if playing up the pump wont be switching into full mode hense the heavy stearing.
try doing a ecu diagnostic and HICAS diagnostic and see if you get an error code. there is info on this in the tutorial section. or if you know someone with a consult cable get them to check for you.
It's a voltage problem. You may well have to replace the battery.
Same thing happened to me a few weeks ago, its definitely voltage, mine turned out to be the alternator had packed it in. The HICAS solenoid was opening and closing with a lack of voltage at idle whilst driving at night with headlights and accessories on. Sounded like there was something caught around my drive shaft and slapping against the foot well but really it was the pressure building up in the lines by the pump and then and getting released sending a shock wave through the lines, it was only audible at a standstill at low revs, when i was moving it just turned into heavy-light-heavy steering as i was turning a corner. My alternator seemed to work on start-up when it was cold (14.5V i think) then stopped working after a few minutes causing rough idle, whine through the stereo and dim headlights. I ended up killing a battery a new battery in the process by dropping it below 8V for too long and it never came back even after i changed the alternator. In the process of getting a battery zapper to see if i can bring it back to life, cold winter mornings are asking alot more from the battery than usual. Its been 2 weeks with a new alternator and haven't had any steering problems which used to happen everyday.
it wasnt the battery or the alt. I went past oh performance and they seem to believe it may be the power steering pressure sensor, so im looking at changing that to see what happens, but i cant seem to find 1. Anyone know where i can find 1?
hey mate. if your alternator is overcharging for example 15volts and over it could be spiking the computer and the system is shutting down because of it saving the components in your power steering. charge rate for all vehicles should be no lower then 13.5v and 14.8v. some of these problems i've seem through my workshop are caused from an intermitted charging fault. the battery wont cause the problem as it is only a storage device, once the vehicle is running the alt runs the vehicle, not the battery. hope the helps.
yea thanks mate, it is overcharging, because what ive realized is when i start the car the voltage sits at around 12v and the steering is perfect, as soon as i give it a rev past 3,000rpm the volts rise to about 14.5-15.0v and the steering is rough.
But another thing that happened that i found really weired is i changed my fuel pump the other day and ever since then, night time driving is great, voltage sits from 13.9-14.3 and steering is perfect but day-time driving sits at 14.5-15.0 again. Thats trippy shit.
So anyway, we've come to the conclusion that the alt needs to be changed.
Thanks for all the feedback guys.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
