iseekool Posted July 22, 2008 Share Posted July 22, 2008 Hi all, I've been intending on purchasing an oil temp and voltage guage for my N/A R34. I came across a genuine triple guage set from a R34 GTT on ebay for a bargain so i decided to purchase it. Does anyone here know how to wire it up? especially the oil temp guage. I imagine the volt meter would just splice into the cigarette lighter wiring. -> and for those wondering about the boost guage - I'll probably just leave it (not wire it up) or find a clock of the same size Cheers Link to comment https://www.sau.com.au/forums/topic/229195-r34-triple-guages-on-non-turbo-r34/ Share on other sites More sharing options...
666DAN Posted July 22, 2008 Share Posted July 22, 2008 Oil temp you'll need to grab a sender unit off a GTT or a GTR and screw it into the side of where the filter goes..then wire to the gauge. Grab a boost sensor of an R33/R33 and wire that to the boost sensor, at least it'll show vacuum. Link to comment https://www.sau.com.au/forums/topic/229195-r34-triple-guages-on-non-turbo-r34/#findComment-4029780 Share on other sites More sharing options...
Vik Posted July 22, 2008 Share Posted July 22, 2008 Yeah thats true. I just bought 3 cups, and 3 gauges which came with the car but were'nt installed. Got DRC to install them for me. Just 100 bucks, i didnt mind because i didnt want the headache. MRXTCZ Link to comment https://www.sau.com.au/forums/topic/229195-r34-triple-guages-on-non-turbo-r34/#findComment-4029865 Share on other sites More sharing options...
iseekool Posted July 22, 2008 Author Share Posted July 22, 2008 Oil temp you'll need to grab a sender unit off a GTT or a GTR and screw it into the side of where the filter goes..then wire to the gauge. Grab a boost sensor of an R33/R33 and wire that to the boost sensor, at least it'll show vacuum. Thanks for that. Would you happen to know the part numbers? and are these sensors easy to install - in terms of no drilling or needing to fabricate anything? Cheers Link to comment https://www.sau.com.au/forums/topic/229195-r34-triple-guages-on-non-turbo-r34/#findComment-4030169 Share on other sites More sharing options...
R34GTFOUR Posted July 23, 2008 Share Posted July 23, 2008 Yeah thats true. I just bought 3 cups, and 3 gauges which came with the car but were'nt installed.Got DRC to install them for me. Just 100 bucks, i didnt mind because i didnt want the headache. MRXTCZ thats cheap as, i wouldnt wire in three gauges for a 100 bucks lol Link to comment https://www.sau.com.au/forums/topic/229195-r34-triple-guages-on-non-turbo-r34/#findComment-4033008 Share on other sites More sharing options...
Vik Posted July 24, 2008 Share Posted July 24, 2008 Yeah it was aiight, he did me a deal because i had mah coil packs installed there aswell and get mah car serviced there regularly. MRXTCZ Link to comment https://www.sau.com.au/forums/topic/229195-r34-triple-guages-on-non-turbo-r34/#findComment-4033425 Share on other sites More sharing options...
666DAN Posted July 24, 2008 Share Posted July 24, 2008 Thanks for that. Would you happen to know the part numbers? and are these sensors easy to install - in terms of no drilling or needing to fabricate anything?Cheers No idea on part numbers, just got to a wreckers....boost sensor is drivers side rear-corner on the engine bay behind the strut tower, the oil temp sensor is a small can looking thing with a wire going to it, joined to the alloy ring that the oil-filter screws into. Should be zero drilling, just running wires Dan Link to comment https://www.sau.com.au/forums/topic/229195-r34-triple-guages-on-non-turbo-r34/#findComment-4033957 Share on other sites More sharing options...
