Hi guys,
I am a newbie so here goes, I have an R33 GTST with an RB25DET in it. Now here is the tricky part, had it rebuilt 30, 000kms ago (spent shitloads mind you) and now it runs like a hairy goat.
Modifications are as follows:
Front Mount Intercooler
3.5" Turbo Back Exhaust
Did compression tests and now no. 5 cylinder has 50 PSI and the rest have 150 PSI on an average. Now in the rebuild, apparently i got a pretty good one due to the fact it cost me around 10 big ones so as you could imagine i am pretty pissed of this is only happend as the garuntee has run out and also when i try to ring the workshop the number is disconnected. this workshop was recommended by the warranty company but i have come to the decission that i will do it myself this time round.
I have mechanical experience, but not when it comes to things like this so i was just wondering if any of you guys out there have come across something similar and if so what was the problem and then the solution.
Obviously every car is different but i just want to know what a may be looking at before i go pulling it all out.
Thanks in advance
Martin
https://www.sau.com.au/forums/topic/229211-got-50-psi-in-cylinder-no-5/
Hi guys,
Thanks in advance
Martin
broken piston ring...or if only cast pistons were used in the rebuild id say a broken ring land.
welcome to the forums....not a good way to start...bugger eh
Edited by DiRTgarage
Have you done a "wet" compression test? Or a leakdown test?
It's most likely going to be in the rings area - a cracked ring can still give some compression. Less likely is a valve, either bent, or maybe carbonned up so it doesn't close properly.
depends how broken it is DG lol and also if its just the one ring thats broken.. :thumbsup:
u didnt reply to my GB question :(
yeah a break closer to the ring end gap will have more compression than a break opposite it as the ring will have no tension on the bore.
what was the question?
Rightio guys thanks for the help i might have a crack at it in the next few months as i have a 07 VE SSV Ute i can drive around in till then so yeah it sucks having two cars hey
once again thaks for the advice this has sort of helped me make up my mind about keeping it cause it was just about off to the glue factory if it were a horse
    • I have engineer in my job title One of or motto's though is "we make and we break"
    • This is actually 2 whole different trains of thought that need to be addressed separately. No, as Matt says above, "Engineer" is not a directly protected title. A lot of guys who just do mechanical design via CAD, with or without even some sort of associate diploma in engineering, often have the job title of "Design Engineer". A train driver can probably still describe themselves as an engineer. But, to usefully get employment with anyone as a proper engineer, you're going to have to have at least the necessary and relevant degree qualification. You're not going to get a job as an electrical engineer if you have a chem eng degree, unless you can demonstrate x number of years of working in that capacity, sufficient knowledge, etc. Having the degree is at least in indication that you've seen the relevant text books, even if you haven't read them (like pretty much the last 10 years of graduates!). To be a self employed engineer.....you could get away with quite a lot pretending that you're suitably qualified, without actually being a proper engineer. But, you will find yourself unable to work for a large section of the client space because a lot demand CVs and capability statements when considering contracting for any engineering work these days. Insurances too. If you're not a proper engineer, it will be much harder to obtain proper PI insurance. Insurance companies have gotten hip to that. The "Professional Engineer" thing is a thing in Australia. If you have the right qualifications and experience you can apply to the relevant engineering top level body (mostly Engineers Australia, the less said about whom, the better), to be assessed and approved as a Chartered Professional Engineer, CPE. There are high bars to get over and a requirement for CPD to maintain it. The RPEQ thing is similar-ish, in that you have to demonstrate and maintain, but the bars are a little lower. It is required to be RPEQ in order to sign off as an engineer on any engineering design in Queensland. The other states haven't fully followed suit yet. There's "engineering" and there's "engineering". Being an engineer that signs off on timber (or even steel) frames for housing projects, council creek crossing bridges, etc, is a flavour of civil engineering that barely warrants the name, description and degree. That would be soul crushing work anyway. Being an automotive engineer working in the space where you have to sign off on modifications to cars and trucks would also be similarly soul crushing. At least partly because of the level of clientelle, their expecations, depths of bank balance, etc. And that brings us to your second question. No, we do not have professional engineers "do vehicle inspections". Well, not the regular roadworthies, etc etc. That's done by mechanics. There might be some vehicle standards engineers at the various state govco inspection stations where cars go to get defects cleared and so on, but that's because they (the cars) are there specifically for defect inspection and clearance and so the stakes are a little higher than on an annual lights and brakes working check. But, if you modify a vehicle in Australia, you have to get it engineered. A suitably qualified (and effectively licensed, which I will get back to) automotive engineer will have to go over the application, advise on what would be required to make the mods legal, supervise some parts of the work, inspect and test the results, and sign off. The "licensed" aspect comes from there being a list of approved engineers to do these things in each state. They have to jump through hoops set up by the govco vehicle standards divisions that mean only the suitably qualified can offer to and approve such mods.
    • It's got a problem Prank... It looks like both washer spray caps have fallen off this car... 😛
    • Meh, it's only got to last another 10 years or so until you'll be forbidden to drive it. Keep it dry and forget about it.
    • The title of Engineer is not protected. However different states have different rules about what an Engineer requires to operate. Engineering for a motor vehicle modification is very different to engineering for a bridge, electronics, etc, including what that engineer needs as certifications.   In Canberra, "Engineer" is the loosest category with basically nothing stopping you calling yourself and engineer and designing a bridge or building. From what I've reviewed, QLD has the strictest requirements through RPEIQ.
