We would like you as a club to join Streetkarz on our first offical cruise, along with Nocturnal Customs and other car clubs.
DATE: 17th August 2008
What to bring,
- FULL tank of petrol
- GOOD attitude
- Cameras (if you have them)
- UHF (if you have them) (will advise of channel on the day)
First meet will be at,
LOGANHOLME HYPERDOME from 9am(arrival) till 10am(departure)
We will be meeting around the back where BIG W is.
We will be there for a while for photos and incase people need to fill up cars with petrol, etc.
From here we will be leaving and heading south along the highway and taking the
YATALA BP exit and heading west towards MT Tambo.
We will be stopping at the BEARDED DRAGON for a short stop to stretch and see how everyone is enjoying themselves.
From here we will be heading around the back of Tamborine......
(This section of the cruise is still being finalised)
From there we will be heading to TUGAN for a BBQ lunch. (same place Nocturnal had there BBQ)
From Tugan you guys are more than welcome to stay and hang around, or you can leave and head to the spit.
Cruise leaders will be split up within the group and will have stickers on the cars, so if you get a little lost or cant find the main group look for the stickers. These will be pointed out on the day also.
Cheers,
Brad
https://www.sau.com.au/forums/topic/229212-invite-to-all-sau-members/
What to bring,
- GOOD attitude
Cheers,
Brad
very ineterested in this guys but im abit new to aussie and dont know anyone on here....... i drive a r32 gts-t skyline its in the progress of being modded getting there slowly.....
Brad
Thanks for the invitation.
The official club has been forced to move offsite due to being overmoderated and unduly targetted by some of the moderators here.
You are welcome to post the invite in the club website and forums at www.sauqld.com
Cheers
Geoff
SAUQld President 2008
  • 4 weeks later...
Hi just wondering if this cruise is only for members and skylines or can anyone with an import come for the cruise.
Cheers!
What to bring,
- GOOD attitude
Cheers,
Brad
Hi Brad just wondering if this cruise is only for members and skylines. We drive an R33 GTST and keen to come for the cruise. My brother in law drives a 200SX and is wondering if he can come for the cruise as well. Cheers Maddog!
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
