Your last sentence is a bit confusing, but if you change your ride and by the sound of it you have coilovers, any height adjustment will generally require a alignment after.If you want people to help you with your questions type them properly.......
https://www.sau.com.au/forums/topic/229213-34-gt-toffset/#findComment-4031989
I think what he is trying to explain is everytime you lower the car, the wheels will start to camber in which allows for more aggresive wheel offsets to be used without any guard mods.
This is from personal experience - optimal offsets lowered approximately 340mm all round measured from center of wheel to guard.
18x8 +30; 18x9+30
18x8.5 +35/+30; 18x9.5 +38/+35
The above with 235 and 265 front and rear rubber respectively will require no rolling of guards. Fronts may have slight scrubbing on inner plastic guard on full lock if lowered excessively. Just quoting offset of wheels without reference to wheel width is useless.
https://www.sau.com.au/forums/topic/229213-34-gt-toffset/#findComment-4032104
factory GTT wheels are 17x7.5 +40 all round.
Well unless the 1000's pairs of factory GTT rims i have seen are are duds, i swear they are +35.even on my 180sx has Gtt wheels which say +35 on the inside of them.But anyway
https://www.sau.com.au/forums/topic/229213-34-gt-toffset/#findComment-4058477
Post a pic of the wheel and we'll tell u if they are indeed the GTT wheels you are refering to.
https://www.sau.com.au/forums/topic/229213-34-gt-toffset/#findComment-4058506
    • Yeah that's true, but idk. Only a 6 month lifespan seems a little short. Oh also, is there a preferred way to send images? Like any sites? I'm used to just being able to upload them lol
    • Hey, like MBS206 mentioned; I dropped off my short block and rotating assembly Monday. With a quick verification, he believes he can clear it up with just a hone and new rings but he will confirm once the rotating assembly is out. If I were you, I would either go stroker or just replace the block if it does need to be bored over to next size. Block is cheaper then forged pistons.
    • live in the UK, and London has introduced a Low Emission Zone (LEZ) that requires individuals to pay £13 if their car doesn’t meet the required emissions standards.   The standard specifies that NOx emissions must be less than 0.08 g/km (i.e., the vehicle must meet Euro 4 standards or better, which generally results in NOx levels of around 0.08 grams per kilometer).   I reached out to Nissan UK, and they advised me to contact Nissan Japan directly. Does anyone have contact details for Nissan Japan or any certifications of conformity that show the emission details or NOx levels for the RB25DET engine?   Any guidance would be greatly appreciated.
    • these guys recommended to me and supplied custom 4 inch mufflers, couldn't be happier. They will spec a muffler to your preferred level of sound and know RB's well.  https://spmufflers.com.au/
    • Yeah this used to happen to me every year and a quick call would at least raise the agreed value back up / reduce the premium, but usually both.    That said for the first time on the renewal this year our agreed values went up or stayed the same over the fleet and the premium came down so that was a nice surprise.
