hey guys im looking for R32 shell??? can pick up as long it isn't to far away. umm... basically doesn't need anything in it have all my running gear/motor/gearbox/interior etc but willing to buy one that is only missing motor and gear box etc. let me know if anyone has anything :D cheers.
https://www.sau.com.au/forums/topic/229351-looking-for-a-r32-shell/
Where are you from so we know how far to far is??? GTR or GTST????
i live in northern nsw, um... haha the closer the better as long as it's no further then i dunno 10hrs away??? so say eg: sydney to gladstone. but if i found a good one further away i woud look into getting it here. a GTST or a GTR either way just need a bare shell or even a GTS shell would do, but a GTST would be best. putting a rb25det in it.
yeh going to be a track car so it doesn't need compliance, where is nisswreck located though arn't you guys in melb??? getting abit far a way i think freight would cost me a arm and a leg to get it here???? what price range are the shells you hav???
cheers
I have a white gtr shell missing radiator support. They are the same as gtst. The guy I bought it off said he used it to repair another car. Dead straight and no previous accident history as it has original paint. Has almost all interior and rear diff etc. Has 17inch lmgt2 rims and adjustable height and damper apexi shocks. Would be perfect to run rwd. Looking for 4k and it has import approval under the old scheme. 93 model. A rwd 25 will bolt straight in. In melb though.
Was going to build it myself into a track car but I've lost interest atm. It comes with stronger lsd diff and drive shafts on a better chassis. You can't go wrong.
I have a rolling R32 GTR shell in Melbourne for 2k but it had some rust (nothing major, but none the less, it is rust)
Maybe this could work well for you, weight reduction??
PM me if interested as I probably won't see this thread again.
Greg
  • 1 year later...
hey guys im looking for R32 shell??? can pick up as long it isn't to far away. umm... basically doesn't need anything in it have all my running gear/motor/gearbox/interior etc but willing to buy one that is only missing motor and gear box etc. let me know if anyone has anything :ermm: cheers.
hey mate, i have a black R32 gtst...COMPLETE car minus engine and box...gtr front seats, momo steering wheel, 3 inch cat back exhaust, king springs..only thing missing is the left head light...$4000
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
