Which tyres are good for road + spirited driving and the ocassional drags without burning a hole in my pocket ?
Looking at 235s and 255s
one more thing, whats the largest width that would fit under GTST guards ? both front and rear ?
*thanks guys*
will really appreciate your help. Thanks again !
:burnout:
https://www.sau.com.au/forums/topic/22938-which-tyres-are-good/
i'm running 275/30/19 in the back falken 451's
they are ok new ..a bit slippy after 5000 k's
Preceda's come in 245/35 only for 19's but have heard some good reviews..about $ 560 ea
i found some hankook k104 's for 400 ae 275/30 but dont know how good they are ...they look huge though :D
Originally posted by EnricoPalazzo
Simex baby! Good for launches!
i had them, they were pretty good.
not i've got a set of the new Dunlop 3000A.
they shit all over the simex. The use them on XR6t/XR8's.
they are very decent.
and what rim size you got?
if you've only got say... 16x8 then it's useless going to 255's
OK I have had the following - all either 235/45/17 or 255/40/17
Goodyear Eagle something - can't remember, cheap, and shit, no grip, but very quiet
Falken GRB FK451 - excellent corner grip, not so great off the line, and still gripped well when worn and pretty quiet
Falken Azenis semi slick - excellent grip when warm, lasted about 6 months, very noisy, not mcuh grip when wet/cold
Falken GRB Tune II - cheap, and it showed - not much grip, in corners or straight line, noisy and lasted about 6000km - but for the money not too bad
Bridgestone S03 - So far so good, heaps of grip in the dry and wet, really quiet - done about 3000km so far and they still look pretty new. On the front now
Bridgestone RE55S - semi slick, heaps of grip - if I can get 10,000km out of them I'll be happy!!, not noisy, good in the wet so far (only 45okms so far!!) No wheelspin in 1st - well priced for what they are, and if you have a bit of grunt, these will get it to the road- so far they are great
And yes, my car gets a thrashing, and goes through its fair share of tyres!! GRB FK451's for value - S03 for pure performance
Hope that helps
dunlop fm-901's are apparently mad. They do well in comparisons such as motor tyre tests.
otherwise maybe try some michelins, my parents have always hed them on their car, and the grip is unbelieveable for the size... not sure which mdel but they wernt even very expensive. WE got P6000's as replacements (on my advide) and the difference in grip is huge, the michelins gripped a million times better...
My friend got 901s for his car in 17/255 17/235 like u, 250 for front and 350 for back from tempe tyres. They are a bit noisy, but excellent grip/handing in wet and dry.
siksII
you got me thinking has anyone done a comparison between top of the line michelin and pirellli tyres on grip
michelin cost over $500 per tyre
pirelli only $380 per tyre
on price for same features I went pirelli but no test drive.
So regarding the michelins can you find out which model?
Are you talking straight line grip or cornering grip?
fm-901's make nice white smoke when they spin and due to their lower grip you feel like your riding harder rubber.
Warning - P-Zeros are very very quiet! although a corner you wouldn't go over 70kph in a brand new volvo you can do at 120kph with PZero's in your skyline, JUST RIDE IT OUT! No drifting!
The time I did that my brakes got too hot and I couldn't slow down enough before the turn. takes about 1 second to drop each 10kph when your brakes are overheating. Freaky.
90 degree left turn - can take at 90kph - 40kph higher than an excel with slightly wider triple sidewall temperature A warmed up tyres. at 50kph.
    • ...just a note of warning, you shouldn't drive it about with the TCU in limp mode with only 3rd gear available ~ apart from the fact you end up sheering the ATF at the torque converter interface, the high clutch in these isn't especially the strongest, particularly bolted to the RB25DE mill...which is likely a 4AX01 box with lighter duty high clutch (the RB25DET got the bigger high clutch)...be careful out there...
    • Hoping to do similar mods to my RB20 once I get it running and reliable again
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
