Which tyres are good ?
Which tyres are good for road + spirited driving and the ocassional drags without burning a hole in my pocket ?
Looking at 235s and 255s
one more thing, whats the largest width that would fit under GTST guards ? both front and rear ?
*thanks guys*
will really appreciate your help. Thanks again !
:burnout:
i'm running 275/30/19 in the back falken 451's
they are ok new ..a bit slippy after 5000 k's
Preceda's come in 245/35 only for 19's but have heard some good reviews..about $ 560 ea
i found some hankook k104 's for 400 ae 275/30 but dont know how good they are ...they look huge though :D
Originally posted by EnricoPalazzo
Simex baby! Good for launches!
i had them, they were pretty good.
not i've got a set of the new Dunlop 3000A.
they shit all over the simex. The use them on XR6t/XR8's.
they are very decent.
and what rim size you got?
if you've only got say... 16x8 then it's useless going to 255's
The best tyres I've given a bit to are Kumo 712's but I haven't tried the tyres mentioned above so I can't compare.
But still they seem to be pretty good tyres for there price.
OK I have had the following - all either 235/45/17 or 255/40/17
Goodyear Eagle something - can't remember, cheap, and shit, no grip, but very quiet
Falken GRB FK451 - excellent corner grip, not so great off the line, and still gripped well when worn and pretty quiet
Falken Azenis semi slick - excellent grip when warm, lasted about 6 months, very noisy, not mcuh grip when wet/cold
Falken GRB Tune II - cheap, and it showed - not much grip, in corners or straight line, noisy and lasted about 6000km - but for the money not too bad
Bridgestone S03 - So far so good, heaps of grip in the dry and wet, really quiet - done about 3000km so far and they still look pretty new. On the front now
Bridgestone RE55S - semi slick, heaps of grip - if I can get 10,000km out of them I'll be happy!!, not noisy, good in the wet so far (only 45okms so far!!) No wheelspin in 1st - well priced for what they are, and if you have a bit of grunt, these will get it to the road- so far they are great
And yes, my car gets a thrashing, and goes through its fair share of tyres!! GRB FK451's for value - S03 for pure performance
Hope that helps
dunlop fm-901's are apparently mad. They do well in comparisons such as motor tyre tests.
otherwise maybe try some michelins, my parents have always hed them on their car, and the grip is unbelieveable for the size... not sure which mdel but they wernt even very expensive. WE got P6000's as replacements (on my advide) and the difference in grip is huge, the michelins gripped a million times better...
My friend got 901s for his car in 17/255 17/235 like u, 250 for front and 350 for back from tempe tyres. They are a bit noisy, but excellent grip/handing in wet and dry.
siksII
you got me thinking has anyone done a comparison between top of the line michelin and pirellli tyres on grip
michelin cost over $500 per tyre
pirelli only $380 per tyre
on price for same features I went pirelli but no test drive.
So regarding the michelins can you find out which model?
Are you talking straight line grip or cornering grip?
fm-901's make nice white smoke when they spin and due to their lower grip you feel like your riding harder rubber.
Warning - P-Zeros are very very quiet! although a corner you wouldn't go over 70kph in a brand new volvo you can do at 120kph with PZero's in your skyline, JUST RIDE IT OUT! No drifting!
The time I did that my brakes got too hot and I couldn't slow down enough before the turn. takes about 1 second to drop each 10kph when your brakes are overheating. Freaky.
90 degree left turn - can take at 90kph - 40kph higher than an excel with slightly wider triple sidewall temperature A warmed up tyres. at 50kph.
 Share
    • As far as I know, Infiniti stopped importing vehicles before 2020, even though they were still selling their stock for at least a year or 2 after that, they were older build years, therefore, you can import a 2020 400R, because you couldn't buy an AuDM 2020 built Q50 RS. As for insurance, you might need to go through one of the enthusiast insurance companies, they tend to insure a lot more grey import models than the mainstream insurers as Duncan mentioned.
    • loved seeing the zenvo on the a1 just after the hatfield tunnel i was the guy in the white van trying to egg you on it sounded awesome and those exhausts glowing red inside insane cheers for the thumbs up tim and tom.
    • So.... when I'm finally getting around to having my power steering leak sorted, now it looks like I've got the same issue most A/T Skylines are having. My A/T light will randomly come on and I'm stuck in 3rd gear until I turn the car off and on again. Only 3 weeks ago I did a complete transmission service: Oil flush + new gasket + new filter. This came out of nowhere!! It wasn't like the car was driven hard. I drove about 3 mins down the road to get fuel and boom!!!  Anyway, I have a few questions and hope you fine people can help me out here. All questions are in red. 1. The solenoids: I was looking at the parts catalogue in Amayama and I could only find the Solenoids as an assembly. https://www.amayama.com/en/part/nissan/319404ax05 I read in another thread that Solenoid A = 31940-4AX02 & Solenoid B = 31940-4AX05 but the Amayama product has only the code of B. Is this the right part? Can anyone who has done the Solenoid changes or seen them confirm if this is the complete set of A & B?   2. Gasket and Filter: I'm not going to try change the solenoids myself because it seems difficult to do in a home garage with just 2 jack stands. I plan to take it to a shop and get it changed. I was also going to buy the transmission sump gasket at the same time so I don't reuse the same gasket. Should I just use the existing gasket as it has only been on the car since OCT 19th? (~3 weeks) Should I be buying a brand-new gasket and a filter? Does this job involve taking the filter out?   Thanks in advance to everyone. It's hard to find a video of someone doing a solenoid change on a R34 so any help you can give answering my remaining questions would make me less stressed.
    • Yea - From what I have seen from the video, the car idles like any R34 lol 50PSI of fuel pressure is hardly super abnormal, the regulator is working because the pressure remains static when the throttle gets revved, i.e pressure remains the same when manifold vaccuum changes. Bigger pumps on stock rails always bumped the pressure in the rail without using an aftermarket regulator to change that. Do you know what your IAC is actually doing? Has there been any data showing the stepper motor % etc? There's no way your idle is actually moving around the way the cluster(s) are indicating. You would hear the difference with the engine RPM flying to 3k and 1k in mere seconds. I'd be checking the wiring to the tacho. What the tacho is telling you and what the engine/ecu is telling you are different things. I assume your ECU doesn't display the spike. So whatever is telling the tacho to be at X rpm is doing something weird. When the going gets insane, you're on the wrong path. You've ruled out plenty of things that are working correctly/aren't the issue. Your idle isn't doing what the tacho is indicating. You have two seperate issues, I don't think they are linked, and the idle seems reasonably okay unless it's stalling which.. well, it hasn't. Troubleshoot the stall if it occurs by figuring out what your IAC is doing vs what it is being told to do.
    • So awesome! I love the RB with the exhaust on display.
