Hey all,
My 94 r33 gts-t Skyline is coming up to to its 200,000KM mark and was wondering do I need to get anything different done then a 100,000KM service?
And also if it is "worth" trying to add on more performance modifications if the KM's are this high.
I'm a car noob so please don't hurt me. Thanks.
https://www.sau.com.au/forums/topic/229387-200k-service/
Hey all,
not really much difference aslong as everything has been fixed/changed at the 100,000km service point. its only another 100,000km service pretty much. obviously at that age a compression test should be done but you should do that at the 100km aswell.
if it has been looked after there i don't see a problem. maybe all fuel lines, vacuum hoses etc should be checked and replaced if you haven't done so.
https://www.sau.com.au/forums/topic/229387-200k-service/#findComment-4032667
Hey all,
you should replace some of the ignition parts...i.e. coils, if you haven't replaced them yet, they start failing around the 200k mark...also check some of the electronics, i.e., water pumps.
have u ever gotten a carbon flush? if it hasn't been done on your car for a while then have it done, it just removes excess carbon build up in the engine.
I'm not an owner but my mums car ('94 bluebird SSS) recently got a 200k service and that's some of the extra things the mechanic replaced.
Edited by INTNS
https://www.sau.com.au/forums/topic/229387-200k-service/#findComment-4032713
the servicable items are all the same, except it is recommended to replace timing belt idler and tensioner, tensioner stud & bolt, timing case seals & water pump in the front. everything else is per usual. i would not go changing coils unless you have an issue. Get a diagnostic done to check sensor operation.
Hey all,
https://www.sau.com.au/forums/topic/229387-200k-service/#findComment-4032762
depends on whats been done and what condition your cars in.
My '93 r33's coming up to its 190,000km birthday and still kicks ass.
Getting the timing belt done on monday, $980... Coils were replaced last service 185,000kms.Exhaust gaskets are getting a bit leaky so they'll be replaced too soon.
https://www.sau.com.au/forums/topic/229387-200k-service/#findComment-4038463
all it has done is heavy duty clutch, fmic, pod filter, atmos bov.
as for its condition the last time i got it serviced at xspeed the only thing they said was the rocker cover was leaking, although im not sure if they did a good job, they seemed a bit flaky...
I've noticed no problems driving apart from the usual atmospheric bov + gts-t stalling issue.
@grubb which timing kit?
thanks for the help
https://www.sau.com.au/forums/topic/229387-200k-service/#findComment-4039478
  • 3 weeks later...
The 200,000km service is a major, just as the 100,000km. On the engine side of things, the major components are:
  • Timing Belt
  • Timing Belt Bearings
  • Water Pump
I offer kits, that include genuine Nissan or OEM parts, and can be found within the following link:
http://www.skylinesaustralia.com/forums/Ni...vi-t137554.html
https://www.sau.com.au/forums/topic/229387-200k-service/#findComment-4079574
    • Would this not be the same for the exhaust you've posted up?  If your exhaust volume and emissions are fine, why does the brand of pipe matter?
    • The issue is more the fact that there is inspectors that deal with japanese cars a lot and they might know what a real Mines pipe looks like. And then they're gonna get antsy and not pass your car. But I'd have to talk to one of them about this, because you know as well as me that it's just a damn pipe and it effectively doesn't do anything. As I need to have my GT2860s and my exhaust setup (and the increase in HP) TÜV'd anyways maybe they can just correct the entry in the papers or assign a badge to the front pipe. I'm no expert either though, will inquire about this.     Thanks for the insight. Not sure if having a custom made pipe is good or not. Will find out in due time I suppose. Would be kind of funny if this was made in Germany though.
    • See this is a really tricky topic as technically the same rules apply to all cars but for cars but there is a difference. If you want to modify a car like the Skyline which never existed here you have a bit more freedom as they do not adhere to EU specs anyway. Any modification you do has to be in dividually checked anyway so as long as one of the inspectors think it's ok and within the TÜV ruleset you can get stuff like a top secret rear diffuser put in your papers. Which frankly would need a shitload of tests and certificates for EU spec cars, like a 2010 BMW M3 for example. But if you DO run these tests and all tests come out ok (safety stuff for the most part) there is no problem running such a part legally. It's just way too expensive to do for a single person on one car. The most touchy parts are emissions related mods, like an exhaust, turbos, air intakes. If it makes noise or alters the carbon emissions it's essentially illegal until you prove it's not. Meaning it doesn't exceed noise limits or have worse carbon emissions. I'd say for hoses if you replace them same same it doesn't matter what material they are or what brand you use. Same for nuts and bolts usually, they won't go and specifically check that your water hoses and some bolts are 100% OEM parts, that is nonsense.
    • What I don't understand here is that it mentions using a sealant. So either way you're ruining the inside of the tire and making a huge mess to clean up. Why not just do that, air it back up to spec, then take it all off and put it back in the car? Also, why not just include a plug kit that's not garbage?
    • What a f**king weener. I have worked in Gary, IN. At the time there were more gun deaths each night there than almost anywhere else in the world. Still not a reason to be afraid. 95% of people from your part of the world only have 3 teeth left from when you were addicted to meth, and now you're perpetually wrecked by Fentanyl. The only saving grace is that most of you didn't vote for Trumpler. Speaking of which, I'm off to the oval office right now. Got to relieve my bowels.
