Hey all, tax return time has come around again.
I have lined myself up some upgraded cams, just wondering do i need a new ECU to go with it.
As im fairly sure the stock ecu wont take it or wont be tunable enough to get all the power gains.
Any info would be great guys.
https://www.sau.com.au/forums/topic/229406-cams-upgrade/
what mods do you have now? the stock cams wont be giving you too much of a restricition if you just have basic mods as it is (which is probably the case if you're running stock ecu), its probably better to spend that money else where.
if you already have the basic catback and CIA setup, maybe go for some headers, or get you ecu "chipped" so it can be tuned, either of those options will give you better gains then dropping in some cams in an otherwise stock engine
also, i would also think of other areas besides just the engine to spend money on. If its a gts, try and source the gtst brakes which would give you much improved braking, or if your suspension is fairly stock get some upgraded springs/shocks or get a new adjustable coilover, or sway bars etc...
depending on how much you are willing to burn (yes burn because you wont get it back, its all fun though), cams probably isnt the best option
Edited by R34GTFOUR
https://www.sau.com.au/forums/topic/229406-cams-upgrade/#findComment-4033003
its a work in progress.
Already have extractors cia, pod.
Cams and head will be done in one go. then coil overs. thats the plan.
I just dont want to stuff around with the standard ecu. plus the computer can be transferred from car to car. so i might actually get some use out of the computer.
https://www.sau.com.au/forums/topic/229406-cams-upgrade/#findComment-4035072
Cams are really a waste unless you want 280kW+, have a laggy ass turbo or are adamant to have fat response.
To bother with buying them, fitting them, retuning = for any less power you won't see a massive gain over stock cams IMO.
But if it's part of your mod plan then go for a decent set (HKS, Tomei).
Cheers
https://www.sau.com.au/forums/topic/229406-cams-upgrade/#findComment-4035092
What about a port and polish before hand? Then Cams?
With a port and polish you could easily get away with using just an SAFC.
Port and poilish will require the head coming off and buying a new head gasket.. but you will see more of gain there and will give cams (if you choose to do so down the road) more of kick up the arse.. especialy with a set of adjustable cam gears too.
https://www.sau.com.au/forums/topic/229406-cams-upgrade/#findComment-4035328
well considering its a NA i want to get all the power i can out of the engine before i work on coil overs.
But its good to hear peoples opinions
My apologies didn't realise it was NA. In that case cams (and yes a P&P too) and gears would be a great addition. You're going to obviously want the extra lift from bigger cams to squeeze more air/fuel in, and if you ported it that would reduce the restriction on that process and you'd get more out of the setup.
Good luck champ.
https://www.sau.com.au/forums/topic/229406-cams-upgrade/#findComment-4035436
yes you will need an ECU upgrade.....unless someone has already said that didnt see anything along those lines tho :P but i could be mistaken.
thats the one thing im glad i did last year....i got a Apexi Power FC.......this will now allow me to do so much to the car and know that anything i want to in the future i am already set up with the ecu.
but when i was talking to my mechanic/dyno guy he did say that a aftermarket ecu would be needed.
i cant wait till i get my cams :) prob wont be this year tho :D but will be hopefully next year ive gone and spend my tax return on some very lovely Isotta Indiana Seats :D i am happy with them lol
https://www.sau.com.au/forums/topic/229406-cams-upgrade/#findComment-4037919
Good to see you turning it into a beast ;)
I heard this deep sounding 33 arrive at DA a month back, looked over and it was you!
Did you free up the exhaust even more or was it always that loud?
If it were me btw, I'd go coils first. While cams and a port and polish will give a bit more grunt, a decent set of coil overs will have you out handling a few few other cars on the road.
https://www.sau.com.au/forums/topic/229406-cams-upgrade/#findComment-4051350
