hey
ive had neons sitting around for a while coz no one could install them.. does anyone know how to hardwire them to the cig lighter?? i've decided to do it myself but i dont know how to connect it to the cig lighter and i dont want to just use the plug
cars a R34 gtt
Thanks
Sunny
Edited by blazindragon
https://www.sau.com.au/forums/topic/229423-need-advice-installing-neons/
hey mate
ok if you want it to run of the cigarette lighter. first remove the middle console, after that you will see the wires that connect up to the cigarette light. best way to do it if you do not want to cut the whole wire off is to, splice both wires, and then make sure you know which one is the positive wire and what one is the ground wire. after you’ve done that make sure the neon’s light by connecting the wires to the + to + and the ground or - to the -. the neon should light up. ok your problem you might have is that your neon will turn on when you turn your interior lights, as the cigarette light turns on when you do so. so that just in case you do get pulled over by cops, and you want to turn the neon’s off. put a switch between one of the wires. for example, the neon wire use the positive side of the wire, and cut it in the middle or preferably where you would like the switch to be along the wire. after that just re-join the wire but join it running through the switch, so that if the switch is off the wire is cannot make the circuit complete therefore no power is given to the neon, and when you flick it on the power will flow through. Remember to solder all connections and tape them up, so no shorting problems occur..
hope this helps, pm me if you need any more help
niran
Edited by niran
just wire it to one of your electrical ports near the steering wheel.looks neat all you gotta do is run the wire straight to a switch that will connect the link and disconect with a fick of the switch...what i did anyway
If you HAVE to do it, look at your fuse box for the interior light circuit and take the power off there. Its about the only legal way to do it.
You will be taking a risk drawing cuurrent from the cig lighter if you don't fuse it.
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
