hey
ive had neons sitting around for a while coz no one could install them.. does anyone know how to hardwire them to the cig lighter?? i've decided to do it myself but i dont know how to connect it to the cig lighter and i dont want to just use the plug
cars a R34 gtt
Thanks
Sunny
Edited by blazindragon
https://www.sau.com.au/forums/topic/229423-need-advice-installing-neons/
hey mate
ok if you want it to run of the cigarette lighter. first remove the middle console, after that you will see the wires that connect up to the cigarette light. best way to do it if you do not want to cut the whole wire off is to, splice both wires, and then make sure you know which one is the positive wire and what one is the ground wire. after you’ve done that make sure the neon’s light by connecting the wires to the + to + and the ground or - to the -. the neon should light up. ok your problem you might have is that your neon will turn on when you turn your interior lights, as the cigarette light turns on when you do so. so that just in case you do get pulled over by cops, and you want to turn the neon’s off. put a switch between one of the wires. for example, the neon wire use the positive side of the wire, and cut it in the middle or preferably where you would like the switch to be along the wire. after that just re-join the wire but join it running through the switch, so that if the switch is off the wire is cannot make the circuit complete therefore no power is given to the neon, and when you flick it on the power will flow through. Remember to solder all connections and tape them up, so no shorting problems occur..
hope this helps, pm me if you need any more help
niran
Edited by niran
just wire it to one of your electrical ports near the steering wheel.looks neat all you gotta do is run the wire straight to a switch that will connect the link and disconect with a fick of the switch...what i did anyway
If you HAVE to do it, look at your fuse box for the interior light circuit and take the power off there. Its about the only legal way to do it.
You will be taking a risk drawing cuurrent from the cig lighter if you don't fuse it.
    • I'm seeing torque specs all over the place for the OUTER tie rod, but none for the INNER tie rod, where it connects to the steering rack. Even in videos, people are just tightening em up as much as they can with a wrench and that's it. Anything tightened down without torque makes me nervous. Anyone know what the spec is for it?
    • Hope you had a great time here in our tiny country.   The JDM scene we have here is quite small, it's mostly BMW, Volkswagen with burble tunes haha. But the few JDM cars we do have in the scene are pretty nice. Some of my friends drive cool s14's too. Both built engines, red one makes abt 500, blue one abt 400 i think?
    • Ye good idea , would have never thought of something like that. Might aswell do it to every pulley and the balancer while I’m there
    • Use an LS1 or similar, via kit like Frenchy's. But.... It's probably not the alternator. It sounds like belt squeal, which would be because the pulleys are glazed. Rub every groove on the pulleys with 120 grit paper. Report back. Oh, and new belts afterwards too. The old new ones will be shitted up already.
    • Hello all I have 2 r34 sedans , one turbo one na, only recently aquired the na 34.  Man what is with these things.... My turbo 34 started sounding like a super charger, it was screaming at anything above 4000rpm , I took the alternator apart and replaced the front bearing which is the only one I think you can access and it did not fix the issue so presumably the bearing in the rear of the alternator is gone. ( diagnosed it was the alternator by taking off the aux belts one by one to figure out which pulley or bearing it was )  My friend gave me one he had lying around, Installed it , it did not squeal for maybe 500kms and now its started to squeal again briefly on startup  Recently got an na r34 and I replaced the timing belt, water pump + all the auxillirary belts. Runs amazing but it suddenly developed the same squeaking problem but significantly worse, Ive had my neighbour come down screaming at me because it was waking her up everytime I moved the car. It takes a good 2 minutes before it quietens down.  Im yet to diagnose where its coming from but im fairly sure its coming from the alternator aswell. My question isnt about how to fix it but rather where can you get a new alternator for an rb25 neo??? Ive searched everywhere but I havent been able to find a direct fit oem type replacement thats not genuine. All the automotive stores sell an oex one - BXA035 - which I picked up for cheap through a friend with staff discount , got it home only to find the connector is completelty different.... As far as im aware bxa035 is for rb20/30's and after a bit of figuring out the bxa035 has an ev14 type connector, which is tiny compared to the rb25 connector. I actually had an ev14 connector lying around which I was considering just replacing the bigger plug with to get the alternator working but the bxa035 is rated for 70amp vs the rb25 alternators are 90amp ( or so ive been told ? ) That paired along with the fact im about to install an amp + sub in the back and I have the stock sized small battery Im not sure itll do the job unless anyone has another opinion?  I know and have seen all the websites selling the ls1 alternator conversion kit but I am not going down that route, nor do I have the money to. Hopefully I can figure out how to get 2 brand new alternators for both cars. I would buy second hand which there seems to be many of but considering how common this seems to be im sure If I installed a second hand one it would start squealing in no time  Or even better if anyone knows how to fix the issue directly with the alternator itself... Any input appreciated Thank you     Link for bxa035 connector picture
