ey guys just need a couple of bits of info. Need to know are the r33 series 2
positive or negative door triggers
where is the central locking module is it under the dash tucked away and hard to get to like the box i saw 2day
wat plug is it how many pins
and what colour are the two lock and unlock wires i need to hook it up 2 my alarm.
Last bit of info i need to get to get this alarm all working properly.
Also any ideas on sum imobiliser points?
and which wire is the engine starter wire as i am hooking up a remote start
also i need a negative tacho wire, any1 know where abouts i can find this?
cheers all
adam
https://www.sau.com.au/forums/topic/229430-alarm-issues/
not trying to steal one are we :P
i think it best you take it to a trusted alarm fitter because im recommending if anyone does know not to tell you
these boards are a wealth of free information about our cars. HOWEVER that sort of information in the wrong hands is what see's them go missing
now i may have over generalised here but
1) we don't know you YET
2) you haven't been with the community very long either
3) so many skylines get stolen each year if your are 110% above reproach then you will forgive us for being cautious
for alarm fitters i recommend Ric at Auto Perfection or John at Marvey Tech, Ric does SAU discount on alarm installs and tinting so mention skylines australia and he will know you've spoken to me
https://www.sau.com.au/forums/topic/229430-alarm-issues/#findComment-4033095
ok thanks for thinking im dodgy but oh well
got my new alarm in, eveyrhting works as afar as central lockin, immobiliser, etc etc
my only problem is that i cant get the remote start to work, i have relay hooked up to the ignition barrel but i dont know if its hooked up properly, any1 have any ideas?
Thanks Adam
https://www.sau.com.au/forums/topic/229430-alarm-issues/#findComment-4034327
Thanks Adam
by the way have a relay with 5 different wires they are
blue red, blue, blue white, thin red and a thin black, need to know is the start on the ignition the same as the starter module, does that wire run tot he same position? CAues says to hook the blue to starter module, blue white to start on ignition and red goes back to alarm as well as black kinda linkign through, ill scan the diagram 2morrow and post it to show u wat i mean but if any1 has any idea son this much appreciated.
Cheers Adam
https://www.sau.com.au/forums/topic/229430-alarm-issues/#findComment-4035425
Thanks Adam
Get remote start installed professionally, unless you want to risk this: http://www.redflagdeals.com/forums/showthread.php?t=476556
And remember, never leave the car in gear when off. :D
https://www.sau.com.au/forums/topic/229430-alarm-issues/#findComment-4036914
And remember, never leave the car in gear when off. :)
yea nah dude i wotn have this problem, i got my self a xxxxxxxxxx 2way pager alarm which has many features include voltage sensing and tacho sensing along with handbrake sensors, so if the car does try and start and the voltage either drops, the revs go all retared wen started in gear or the hand brake is down the car will die instantly/wont start at all, so it should all be fine. THanks for the heads up anyway i thought of all thsi ebfore doing it anyway
edited by Nightcrawler: mate don't tell potential thieves exactly what brand and model alarm you have - that is just dumb
https://www.sau.com.au/forums/topic/229430-alarm-issues/#findComment-4037512
^^^^ how dumb is that guy to 1) leave his car in gear when he has a remote start system, and 2) make sure the installer installed the neutral sensor property. That should not be physically possible to happen. And how did the car start in gear with the handbrake fully on. Sounds sus to me. Just for fun those guys with manuals try to start your car with the handbrake on and in gear - I guarantee that you won't get very far. Feel free to correct me if I am wrong.
https://www.sau.com.au/forums/topic/229430-alarm-issues/#findComment-4037531
Yea, if the handbrake was on, the car would just bunny hop - instantly stall and shut down...
https://www.sau.com.au/forums/topic/229430-alarm-issues/#findComment-4037755
anyway thanks guys for the help, not, foudn the wires i need i think. Tried 2 hok up the rmeote start but with no luck yet, dunno wat i could be doin wrong. Oh well ill figure it out one day. At least everythin else is workin. Cheers anyway
https://www.sau.com.au/forums/topic/229430-alarm-issues/#findComment-4042097
    • Sag as in the windows start to slowly open themselves, or they're just slow to go up/down with engine off?
    • It looks like it needs a big worm gear drive on it to control the rotating, not a few sloppy pins!
    • As Duncan said, first there was OBD, which few cars used, then came OBD2.   Now an interesting point, OBD2 isn't even for what you want to do. OBD2 is for emissions testing. There is some sensor data on OBD2, but it's up to the manufacturer what they're putting on it. Most scan tools operate on UDS, which like OBD2 is a standard built on-top of CAN. UDS specifies how to structure a message, what very limited things mean such as "read memory address" but it does not specify what is stored in which memory address, that is all up to the manufacturer. You either a scan tool compatible with that vehicle, or to know how to reverse engineer all the data, which can take a VERY long time and a lot of vehicles to get it right. Oh and then the manufacturer does a firmware update and changes what's where... Ask me how I know that as fact Oh, and by the time you've got the scan tool that supports all the manufacturers stuff, well, you're back at "But a consult cable and the Nissan software" The main difference being most manufacturers software these days works with the same hardware readers, as the readers are built to support J2534 which is another standard for how the PC communicates with the tool to make it do specific things on the car...
    • Rotisserie is fully assembled apart from centre connector which obviously isn't required until the car is on it. It packs away fairly neatly and doesn't take up too much room. (Now that I actually have some room after my clean up!) Overall very happy with the quality of it.  Assembly was a piece of piss.  The only thing I didn't like was that the pins that lock the rotation lock wheels in place were a bit of a dick in a bucket scenario. It allowed the arms to rotate a significant amount even when locked in place.  To fix that i measured up the hole and went and grabbed a couple of 18mm fully threaded bolts and a thread tap to suit. I ran the tap through top and bottom so it was threaded both ends.  Then just threaded the bolt through both sides.  It has made a massive difference which hopefully you can tell in the before and after video how much difference it made. 20250207_161431.mp4   20250207_161431.mp4 Hopefully back working on the car over the next few weeks.   20250207_162801.mp4
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
