Ive been searching for a bit and i cant find any solutions to my problem. I currently have a WC34 Stagea Automatic ECU running my manual R34 Skyline GTT drivetrain. This is all installed in a USDM S14, running fine and everything. I was wondering if the fuel and ignition maps are very different between manual and auto ECUs. I know most cars (such as z32) have completely different maps between transmission models, are RB cars the same? Am i losing a bunch of power and fuel economy? My 02 readings are right on, but the car runs through fuel like a diesel!
I appreciate it the help gents.
I don't have a direct answer for you but ... there are a number (3 or 4) of different Stagea computers although all appear to have pinouts like the R34. For example mine is numbered OV300 and I have an auto with an RB33 series 2 engine. Your best bet is if you could borrow a Skyline R34 GTT ECU and see if it runs differently
Hmmm. Theres definetly no way for me to borrow one, barely anyone in America runs RB25s let alone Neos. Ill have to check what my ECUs Part Number is and post it on here. What do you have your ignition timing set at? 15* or 20*?
Factory is 15* for both Stagea and Skyline R34 but if you're looking for economy just keep advancing it until you get detonation (Knock or pinking) and then retard it a little. I'll look out for a GTT ECU but must say Stagea ones are easier to get hold of (I'm in NZ). My Stagea is probably heavier than your car but I only get about 15litres per 100km (that should take you a while to convert to MPG)!
(later) I had a quick look on the auction site but plenty of ECUs but not R34GTT. I could possibly locate one for you if you are real keen (probably $100 to $200). Depending on your financial situation the ideal solution would be an Apexi FC which would replace your ECU and be completely programmable for most everything (often available on Ebay) for around $1000 ...here is a local example:
http://www.trademe.co.nz/Trade-Me-Motors/C...n-166522943.htm
  • 2 months later...
Well im still in the hunt. If someone could find me an R34 GTT Manual ECU, id really appreciate it! Ill give a finders fee!
    • But it's much better to use a freedom unit that has four different possible meanings...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
