Item: Full custom leather re-trim for R32 coupe (including some stereo components)
Age: 3 years
Condition: very good
Price: 4500ono (plus swap for stock trim)
To Fit: R32 coupe
Contact: [email protected]
Comments:I'm selling the trim out of my R32 due to rebuilding the whole car
trim was done my Master Auto trim (one of if not the best trimmer in the country)
what you get is the following
-East bear R34 GTR front seats slightly reshaped with Bride rails.
-R32 GTR rear seat reshaped
-R32 Door trims custom moulded to fit Focal 3 way splits (speakers included)
-Custom parcel tray to house 4 x 6.5" MB quart splits (speakers included)
-Complete dash with holes for 3 x 60mm gauges
-All interior plastics have been chrome plated
-Fibreglass boot mould to house 4 x 12" subs and 2 amps (subs and amps not included)
-A, B, C pillars and roof lining trimmed in bone suede
this price is about 1/3 of what it cost me to get all the work done so IMO this package is dirt cheap
-Seats and rails cost me $2500
-Custom fibreglass moulding cost me $1500
-Chrome plating all plastic parts cost me $2500
-Focal speakers and MB quart speakers cost me $1700
-Leather trim work cost me $7000
in total thats over $15 000
Hey Ford,
I'm gonna get a weld in roll cage which means i have to cut up the dash and stuff so i would rather do it to a stock one rather than a trimmed one
Age: 3 years
To Fit: R32 coupe
Good luck,
If it was for a 33 i woulda snapped it up, it really looks good..
  • 1 month later...
I am absolutely bewildered that this is still here.. do people not realise how expensive it is to do this stuff? That interior is absolutely f%$#ing mint! I can't believe its here.. if i could twist it into my GTR i would buy it.
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
