use the power wire to the std overtemp thermo fan as a signal wire to another relay to run your thermos. but i very much doubt you could modify the switch position in any way.
perhaps the powerFCs laptop software has an option, but i havent looked at it.
https://www.sau.com.au/forums/topic/229482-rad-temp-sensor/#findComment-4040407
Yes, all of us silly buggers with thermo fans have been down this route.
Tridon TFS141 is the most used switch, 85 on, 80 off.
I think it's too hot for a bottom tank install, but the Tridon range is a bit limited in the M16 x 1.5 size.
Champion also make identical switches, available from REPCO.
Haven't seen an option for controlling the thermo fan via Datalogit.
Engine driven fans FTW.
Edited by grigor
https://www.sau.com.au/forums/topic/229482-rad-temp-sensor/#findComment-4040524
