94 GTR SKYLINE
Tein Coilovers
Strut Brace Front Rear(Aftermarket)
Apexi Boost Controller
HKS Oil Cooler Kit
R33 GTR Wheels
R34 GTR Turbos
HKS Pod Filters
New Gtr Fuel Pump
Sports S/Wheel
Replaced Injectors/AFM'S
3Inch Exhaust
Turbo Timer
Alarm
New Clutch Master Cylinder $250
T Clamps On ALL cooler piping $200
Gear Box Removed /stripped and replaced 4 syncro $700
Jamie at JRM Transmissions said the Gear Box was in excellent condition
Extreame 6 puc clutch
CP forged pistons
SONY Stereo
Aftermarket 330km/h Dash
Gun Metal Grey the darker of the 2
Car is in good condition and is very fast
0415562946 thanx....
22k ono
https://www.sau.com.au/forums/topic/229504-r32-gtr-94-model/
Forgot to add it has TCS Traction control system 4wd/2wd switch this lets you put as much traction on the front diff as you like one of the best modificaions you can do to a 32 gtr price $500...
Edited by luke james
Getting new clutch as we speak and will be putting new DBA4000 series brakes front and rear plus SRT pads so price change $22500 ono car will be ready for track days Nothing to spend!!!Very fast GTR!!!
    • That's a given!  Bit hard to powdercoat it properly without removing them! 😁
    • No detail on compressor or turbine sizes, which doesn't help with housing size selection with that kit. However, from SR20DET mucking about and money torching perspective, a GTX2860R Gen 2 w/ 0.64 (46mm inducer) will do ~260kW on E85 about 1.5bar of boost. All in before 3000pm, which cause a gearbox to shatter. Now imagine the same turbo, on a modern motor with an extra 0.5L of displacement, and heaps of cam timing adjustability (not an on/off affair like the Nissan shit boxes). If this was my car (which I would never own or consider buying, ever!), I would go for a nice twin scroll setup, and a G30-660. Gates plumbed back, no silly shit. Lean on the cam timing, big displacement to create a flat-ish torque curve.
    • Do you plan on using 98 or e85?
    • This should be pretty easy. 200rwkW is just about the max power out of an RB25 stock turbo. So, 12ish psi on a 2.5L. That boost limited mainly by the prospect of seeing the turbine in the cat after the smoke show. A steel wheeled equivalent would likely happily do ~220rwkW at something like 17 psi, where it would probably be bumping into the usual limits of such a sized turbo. These things have like a .48 rear. You will not need the 0.86 rear. The 0.64 will be fine. In fact, if you were looking at various mid-200rwkW options for RBs, most of them would be in a 0.64 rear. So, I think you will definitely want to be no bigger than that for a same sized but probably even more efficient (at making power) modern engine.
