i apologise if this has been covered before, used the search but didnt really come up with much info that i wanted.
i am looking to finish off my cat back exhaust. basically want a few peoples opinions on the best dumps/hi flow cats for r33 gtsts.
car is not highly modified, will be aiming for 200rwkws at the max when im finished with whatever mods i decide to buy in the future. just a quick daily driver.
so what would be the best/most cost effective dump/front pipe and hi flow cat that i should be looking at buying?? want something that is reliable and flows really well.
cheapest option obviously is the xforce range, but ive heard from a lot of people that they are shithouse?
i also have been looking at the BOS importing stuff, and it looks and sounds the goods, but is pretty pricey.
will obviously shelf out top dollar if need be, if its the only stuff that is going to work well, but thought i would grab some opinions from people on what they think or have experienced
cheers
https://www.sau.com.au/forums/topic/229513-ideal-dumpcat-for-r33/
I have had a bat mbl stainless split dump/front pipe in 1 and catco high flow in 3 inch
with a std GTR cat back on a R32 gts and it made very good power in the mid
range and top end while still being legal.
I revised this to a hks split dump with a hks front pipe with the catco cat
converter with trust pe11 cat back and although these are good well made jap
parts they didn't perform as good as my old set up
If I had my time again I would of stuck with the old set up BUT fitted a flexible
joint to the bat mbl (boss imports) front split dump and front pipe in 1 to make
it fit better but apart from that they do make good power.
I have had the bat mbl pipe next to a just jap pipe I would advise you to steer
clear from the cheaper just jap stuff as they are not as good the flange wasn't even
square.At the end of the day you get what you pay for
^^ that isn't a metal cat xforce cat.. xforce also have metallic substrate cats.. not ADR approved though
my guess after looking at metal cats for a while and still undecided.. xforce metal cat < magnaflow metal cat < catco/Metalcat < sard/apexi cats (ridiculously expensive)
so u guys reckon a split turbo back pipe, rather than a bell-mouth turbo back pipe...
correct?
i heard split ones get bad back-pressure...
i think it was back-pressure...lol
i too am in the market for a turbo-back pipe..
i had a jjr split dump/front and it was fine for the old stock turbo. not a problem in the world!
for the price it was a great mod.
i now run a 4" hks bellmouth and a bigger turbo but installed them @ the same time so cant really comment
I was leaning towards a JJR split front pipe, as at the end of the day its just a welded and bent pipe. i figured that making 200 rwkws, it wouldnt be under too much stress, since some people have said on here that with bigger power they can warp and crack or whatever. If a few people here have said with the same kind of mods i have that it works well then that gives me a bit more confidence in their stuff.
I might spend a lil more on the cat though. ive heard a helluva lot of stories about the xforce ones collapsing/having shit flanges and welds etc.
Might look into a catco cat from bos importing for the cat, what are peoples experiences on them??
Yeah split pipes are a lot better bumble bee, because the bell mouth ones have a larger opening, it can give you a loss in pressure as there is more volume to fill in the opening, whereas the split openings have less space for the exhaust to travel about in the mouth before continuing on its journey to add to the greenhouse effect haha. i believe thats about correct? although i wouldnt imagine the difference in the two to be really huge?
You will be surprised how many times people have bought split dump/front pipes that don't fit and need modifications to get them to fit on the stock turbo. Regardless of what the seller might say it is a "direct bolt on". I ended up sending mine back for this same reason and sticking to a proven 3 inch bell mouth style. As for the cat, very very few will have an ADR stamp on them. Nearly all compliance cats don't have any stamps on them and they are used to first register the car in Australia with no problems. You really won't have any problems with this as long as you have a cat on the car in the first place.
the bosimporting 5" cats are not catco anymore. the external design is identical (as far as i can see) the welding was decent on mine and it looks for all money like it will flow as well as any other 5" bodied cat on the market.
on bellmouths, back to back we made a little more power everywhere with a bellmouth than with an expensive name brand split dump at or around 230-250rwkw. don't rule out the bellmouth dump as being inferior. i think it is a close thing between them, perhaps higher power levels/exhaust flows are needed to see a clear advantage?!?!
in some cases the extra money for a split may be better being spent elsewhere.
if BOS doesn't sell the CAtco any more, who does? and whats the best place to get it for a good price?
why do you specifically want a Catco?
the current bosimporting cat looks the biz, the metalcat looks the biz etc etc. they all seem to flow near enough the same to make decent power.
Good luck finding a CATCO or MetalCat anywhere. I have been looking for the past month and have been unsuccesful in locating any so i have gone with a Magnaflow for now for my gtr. Also the cats now sold by BOS importing are not a metal body but ceramic.
no reason for specifically wanting catco. its just that bos importing's flow test claimed them to be better than the metalcat. if their current flows as well then shouldnt be a problem. anyway metalcat is probably also a bit of over kill on my car. just wanna stay away from the x-force ones. heard bad things
    • Thanks, I removed the fuse and the relay from the car and made my own circuit with them to test them with a test bulb.  I will look for the wiring diagram and go from there.
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
