hey guys i hope this is in the right section but i was wondering if the cross member from an R31 could get swapped out with a S13 cross member as i have a fully worked CA sitting here and i was figuring the cheapest way for me to get it sliding again would be to mount it in an R31 shell
any ideas how much work would be involved in doing the swap over - i would probably run an S13 rear end as well if that makes the conversion any easier
any help would be appreciated
https://www.sau.com.au/forums/topic/229530-r31-cross-member-swap/
In a Pintara, the motors are a bolt in but they do sit a LONG way forward and high , I'd be thinking about making lower, rear set mounts. Question covered plenty of times on the r31skylineclub boards.
S13 rear end won't swap easily into any R31. Imports have IRS but its completely different (Datsun style trailing arm) and aussie delivered cars have a borg warner live axle/4 link setup.
Edited by floody
putting an SR20 s13 crossmember in an R31 is a piece of piss.
go to an engineering shop with your s13 xmember, and ask them to move the front hole forward 35mm.
I found that the crossmember slots straight onto the standard mounting studs and when fitted with an SR, it sits right back almost touching the firewall, right where you want it :P
I have done the ca conversion into a r31 pintara(the purple pinny) it works well.
even positioned like the old ca20e motor .
ive also done a sr20 conversion into a r31 pintara ....... not once but 2 times now 1 has a s14 sr20de motor in a pinny with the std crossmember and redrilled holes 10mm forward or back i cannot remember .
and the other is a s13 sr20det red top into a pinny using the s13 crossmember modifyed to suit a r31 ,then a s13 steering rack, hr31 rack rods for the kyb rack ,hr31 front struts
i cannot see why the ca s13 crossmember wont work and make the ca18 sit as far back as possiable , but same deal aplies your gonna need s13 rack hr31 rack rods to suit the kyb rack and then hr struts or you could go s13 rack rods and s13 struts etc
if ya need any more info just pm me
    • There aren't boost creep issues, it's not engineered around the restriction of the cats but if you haven't tuned the engine a full decat + exhaust can flow enough air to run off the end of the OEM load scales and you will get a pretty substantial reduction in ignition timing as a result. I recommend using DFCO, avoiding ignition cut limiters, and avoiding popcorn tunes along with running a cat unless you enjoy a perpetually soot-covered and potentially burnt bumper.
    • Small update, it's been slow moving over the Christmas period with money having to go everywhere thats not my car 😅. I got myself a little present to myself from "santa" in the form of some tidy radiator mounts from fitmint automotive to get rid of the stock ones that look like they have been in an accident before and then straightened by a caveman. I know I should've replaced the rubber bush at the same time but I had no idea how bad they were until I was replacing the mounts. Decided to order their dash mat while I was at it as I feel like I am lucky enough to have a pretty decent condition dash and I don't want to risk it being ruined while it's parked in the aussie sun while I'm at work. I have found another electrical fault to add to the evergrowing list to eventually chase down. Every time I replace my taillight globe it blows within a day of use, I'm starting to think my life would be easier if I took a few minutes to learn how to use  a multimeter 😂.   Had some luck with finding a series 2 drivers headlight on marketplace to replace my mismatched series 1 headlight, a subtle difference but it's nice to have a matching set of lights now.   I returned to the air con problem due to being sick of this summer heat, found a good condition condenser to replace my leaking one! I got it in the car and was happy when I got the thumbs up that the system was now holding gas. Sadly the compressor is not kicking in for some reason, we even tried branching the relay in the fuse box. I have tried to do some research on the issue with no clear understanding of what the fix is, so for now it will be placed on the backburner until I can be bothered to look into the wiring to the compressor. The last small mods I have done was cutting the horizontal vents out of the front bar, not really in a functional airflow sense but I just think it looks better as I am not a fan of the series 2 bar. I also switched the shift knob out for a hosoboyo aluminium grex style one, it has a really nice more direct driving feel than the outdated rubbery oem one. Thirdly, I chucked on one of the ebay bonnet strut kits. The fitment is decent and they seem to work fairly well. They have only given out once while the car was parked facing downhill, I think if I was working under the bonnet I would still put the oem hood stay up to be precautionary as to avoid getting a speedy concussion.
    • Got pneumonia, haven’t played with her in a while, but I’m back now. Previous owners cut bonnet pins into the bonnet. My choice try find a replacement or spend $15 get some pins myself to cover up. Now only one small hole to cover. looks shit now, but when the bonnet is red again. Be good 🤞
    • No R32 GTSt had 15" wheels. 205/55-16 was standard GTSt fare. 4.36:1 is standard R32 turbo auto diff. I think the manual was too, not 4.11. 4.11 and 4.08 were R33 namual and auto respectively.
