geez!
that was a stab in the dark!
well im looking at getting a system done on the r30
i was wondering why it has a cat? is this actually of an R30?
im trying to visualise how it all fits up
and im in canberra, can drive to syd, so if you know of anyone traveling south we may be able to arrange transport
i can use an aftermarket S13 system from the local importer, but thougth to see how this looks first... any pics of it installed
and have you got anything else R30 related for sale>>>???
maybe its an FJ/DR emissions thing?
the aussie L24e in the series 2 MR30 had steel 'pipes' in the exhaust ports that heated up and burnt un-spent fuel, so maybe that was enough for it to pass the gas testing, not needing a cat....
cats pretty much become useless after a few years anyway... feed em to the dogs eh!
you must run all original EPA gear on your car that was released with your engine. As far as I know all FJ20's had a cat, I definitely know the L20ET's did. So if it came out with a cat technically to get it engineered you need to have a cat.
Does anyone else maybe know? I am interested if they fit a coupe.
cheers
same man. sory to high jack this threade i no these are sold but i got some K macs springs good nic, pm if u intersted
D-Limo
Can you:
get the exhaust,
wrap it in some packing tape to secure it together,
then wrap it in a few meters of clingwrap
Get the dimensions (length, width, height)
Get the weight
and pass these all onto me... (incl your postcode & suburb)
will be getting a quote from busfreight with this information
Then I will see how much they will charge to get it here!
If all else fails, I'll get my brother from carina to pick it up.
Have you got anything else M/D/HR30 related you loking at selling?
D-Limo
Can you:
get the exhaust,
Get the weight
I can do this.
But I need proof of comitment before I pack it. email me at [email protected]
Only other r30 bits I have are rear koni shocks to suit rebuild wich you can have
cheers,
jarryd
Edited by D-limo
    • If the RB29 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
