76 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 66
The wet carbon pieces are available now for R33 and R32 (we have a handful of the gear stick surrounds) on a trial basis. If by the end of the trial the majority of people have said the fiddling is acceptable then the dry carbon will not be produced as the set-up costs of dry carbon are very expensive.
What pieces? so far all I have seen is the gearstick surround. What 33 parts are actually available.
The gearstick surround is the test piece to determine if the wet lay-up construction has the approval of the customers ( you guys). I applaud them on taking direct feedback from customers.
Will any R34 parts be produced in the future, and if so, which parts? Interested in a CF triple gauge cluter and so fourth. Is the fit OEM quality?
What parts are produced is up to Sniper Racing. Unsure about the fitment, that's what the Beta Testing is for.
Dry. How far away is the rest of the dash from being completed
I don't have any dates. Sniper Racing has asked us to do the trial on there behalf, as they are a wholesaler and thus have no customer base to draw comments/feedback from. The construction type will be determined from the feedback of those conducting the Beta Testing.
If & when, I am willing to Beta test the R34 Parts. :P
i just brought a whole heap of cf parts from japan and should be here late this week/early next.
look awesome and different
hi
i just would like to ask you where did u get all these parts?
i have er34 too a ive been looking for these parts for an ages
thanx and they all look amazing
hi
I have a mate who brought them off the japanese auctions. Will all be here tomorrow :P
For all of those who have bought parts through the Beta Testing program, can you please email back your work logs ASAP as the sooner this happens the sooner they will become available for retail production.
Whats the difference between wet and dry carbon? lololol
I'm going to be writing up an article soon as this is quite a common question.
sorry just saw above posts..
Interested for when R34 components arrive/to be tested..
Thanks.
Once I hear something I will let you guys know.
    • Yeah. OK. I'll say the same thing I say to everyone. You do not have to use 100% throttle all the time.
    • Mainly being afraid of breaking something on something i've poured so much money into haha
    • Hey   ive gone for a terminated harness on my build so selling brand new unused and unopened piggy back harness  https://www.haltech.com/product/ht-141357-elite-2000-2500-nissan-skyline-r32-33-r34-gt-r/ Located Bathurst NSW   price $600 + postage
    • The trigger kit I have is similar to the one in the link below. While going through Facebook, I saw someone else mention a similar issue, and I’m starting to think this could be related to the crank gear itself. I understand these parts are CNC machined, but maybe some earlier versions or individual pieces might have slight inconsistencies—it just doesn’t look right in my case. https://www.facebook.com/share/16an8evZd9/?mibextid=wwXIfr I originally installed the crank gear using the thin OEM washer, but as shown in the attached photo, the timing belt walks very close to the edge. When I tried using a Nitto washer—which is thicker—it actually made the issue worse. The belt walks about 1mm off the front edge, which raises more concern about alignment.   I’ve gone through the full process of elimination:   The tensioner pulley and bolt are brand new and installed correctly. The bolt isn’t bent and is oriented properly. The back of the tensioner and the idler pulley are clean and seated correctly. The idler sits slightly more forward, which I understand is due to its design. I’ve experimented with both tight and loose belt tension, but it makes no difference. As soon as the engine runs, the belt immediately walks forward again—even if I reset it beforehand.     At this point, I’m considering replacing the crank gear with your Race Version 1 (12-tooth), but before purchasing, I wanted to ask:   Are you aware of any alignment issues when using this gear? Would this gear help keep the belt aligned correctly, or could the walking still occur? Does it work with a standard missing-tooth crank and rear washer? Is there any specific crank setup or install procedure required?     For reference, I’m not using a front washer, as the PRP crank gear seems to replace the need for one.   Looking forward to your advice.
