335 Posted July 24, 2008 Share Posted July 24, 2008 (edited) Hello I have a R32 GTS-T. I put a R33 turbo on it. It has a HKS adjustable acuator. I have it set at .5 bar. Going to set it at .8 or .9. I have a catback exhaust, intake. What else should I do next? I have a R34 SMIC that I haven't put on yet. I want to get the most out of this turbo that I can. Should I get a GTR fuel pump or a Nismo 4L pump? Should I put in GTR injectors or Nismo ones or keep stock? Do I need a aftermarket computer now? Should I go with the down pipe/ front pipe? Do I have to tune if so? Later, in the winter time, I will buy a friends TD06 but cant afford it right now. Later going to get Emanage, and FMIC. I have read and read and I really don't know where I should go from here. There is a big improvement in response and speed just from having the R33 turbo on there. Help! I want to do next important upgrading!!! I live in Japan and the area where I live gets only about 30-32 degrees celcius in the summer on average. Edited July 24, 2008 by 335 Link to comment https://www.sau.com.au/forums/topic/229546-my-r33-turbo-in-on-my-rb20-dont-know-where-should-go-next/ Share on other sites More sharing options...
NWR31 Posted July 25, 2008 Share Posted July 25, 2008 well i have a stock rb20 with rb25 turbo, 3" turbo back exhaust (no cat), bosch 910 pump with surge tank, 600x300 fmic, safc II, manual boost controller (turbo tech) & thats it. gives a responsive 250hp atw, but larger turbo, injectors afm & nistune flash will be going on pretty soon. Link to comment https://www.sau.com.au/forums/topic/229546-my-r33-turbo-in-on-my-rb20-dont-know-where-should-go-next/#findComment-4037206 Share on other sites More sharing options...
joeyjoejoejuniorshabadoo Posted July 25, 2008 Share Posted July 25, 2008 full zorst next! 11ty% Link to comment https://www.sau.com.au/forums/topic/229546-my-r33-turbo-in-on-my-rb20-dont-know-where-should-go-next/#findComment-4037526 Share on other sites More sharing options...
335 Posted July 26, 2008 Author Share Posted July 26, 2008 well i have a stock rb20 with rb25 turbo, 3" turbo back exhaust (no cat), bosch 910 pump with surge tank, 600x300 fmic, safc II, manual boost controller (turbo tech) & thats it.gives a responsive 250hp atw, but larger turbo, injectors afm & nistune flash will be going on pretty soon. Cool Why the surge tank? Does the fmic give much lag? The reason I am going with the R34 smic is because I read on this forum that it is about 50% bigger than stock. So its shorter travel for the air to the turbo so hopefully not a lot of lag. What kind of larger turbo are you putting on? What is a nistune flash? Why a safc II instead of a computer? Thanks Link to comment https://www.sau.com.au/forums/topic/229546-my-r33-turbo-in-on-my-rb20-dont-know-where-should-go-next/#findComment-4038086 Share on other sites More sharing options...
mark_sudakov Posted July 26, 2008 Share Posted July 26, 2008 I would put the exhaust and r34 smic before boosting. Its best to no not go past 14psi on stock r33 turbo otherwise it starts to get risky. But when u do boost, you should get a tune. Link to comment https://www.sau.com.au/forums/topic/229546-my-r33-turbo-in-on-my-rb20-dont-know-where-should-go-next/#findComment-4038090 Share on other sites More sharing options...
335 Posted July 26, 2008 Author Share Posted July 26, 2008 I would put the exhaust and r34 smic before boosting. Its best to no not go past 14psi on stock r33 turbo otherwise it starts to get risky. But when u do boost, you should get a tune. Thanks I will finish the exhaust(downpipe, front pipe, better cat) after I get a computer. I will put the smic on within the next two weeks. Busy with work. I will not be able to buy a computer and tune for about 1 to 2 months due to having to use money for something else. Is this fine? I will make sure not to set it about 14 psi. Link to comment https://www.sau.com.au/forums/topic/229546-my-r33-turbo-in-on-my-rb20-dont-know-where-should-go-next/#findComment-4038130 Share on other sites More sharing options...
NWR31 Posted July 26, 2008 Share Posted July 26, 2008 (edited) CoolWhy the surge tank? Does the fmic give much lag? The reason I am going with the R34 smic is because I read on this forum that it is about 50% bigger than stock. So its shorter travel for the air to the turbo so hopefully not a lot of lag. What kind of larger turbo are you putting on? What is a nistune flash? Why a safc II instead of a computer? Thanks yeah the surge tank is a bit of overkill but it & the pump were installed by the previous owner when the car had a different motor. this setup is very responsive with sfa lag imo & i wouldnt run anything else but a decent fmic. it has custom cooler pipes & the cold side pipe (after the cooler) is fairly short compared to some setups ive seen. anyway i dont mind a bit of lag especially if you can run say 20psi & have a real good hit of power. the safc was put on by a previous owner cause when he bought the car it had been bought back to pretty much stock. it was running autronics & hks turbo etc before he bought it. the car is making reasonable power with its basic mods & a lot of that is probably due to the safc. im going for a nistune flash instead of a new complete ecu cause they are only about 800 bux tuned & do the job i believe. the turbo thats going on is a s/hand (6 months old) Apexi AX53B70 P-25, its a bit smaller than i probably would have liked but for $1000 for the complete apexi kit (turbo, dump, braided lines, etc) it was pretty hard to pass up. cheers Edited July 26, 2008 by norwest_rumbler Link to comment https://www.sau.com.au/forums/topic/229546-my-r33-turbo-in-on-my-rb20-dont-know-where-should-go-next/#findComment-4038301 Share on other sites More sharing options...
Grunter Posted July 27, 2008 Share Posted July 27, 2008 Hi mate I have headed down the same path as you when you do decide to go down the path with a computer upgrade to handle all these mods. I would higly recommend that you go n see Dr Drift for a reflash chip for the std computer as this is what I have done and the results have been unreal totally different car to drive shit loads more mid range and can drive the car on the throttle more around the race track.This has been the best mod I have done on the car so far,and a lot cheaper than a pfc. Good luck with it Link to comment https://www.sau.com.au/forums/topic/229546-my-r33-turbo-in-on-my-rb20-dont-know-where-should-go-next/#findComment-4038907 Share on other sites More sharing options...
mark_sudakov Posted July 27, 2008 Share Posted July 27, 2008 or u can go with a CEF11E remap for $100 or Toshi's remap for abit more Link to comment https://www.sau.com.au/forums/topic/229546-my-r33-turbo-in-on-my-rb20-dont-know-where-should-go-next/#findComment-4039484 Share on other sites More sharing options...
NWR31 Posted July 27, 2008 Share Posted July 27, 2008 he lives in japan so are these reflash options really viable? can he send them his ecu & they modify it & flash a generic tune to suit his mods? i would have thought a live/real time tune was the only type worth having Link to comment https://www.sau.com.au/forums/topic/229546-my-r33-turbo-in-on-my-rb20-dont-know-where-should-go-next/#findComment-4039904 Share on other sites More sharing options...
Grunter Posted July 27, 2008 Share Posted July 27, 2008 Mate stick with Dr Drift he has tuned hundreds of these and has years of experience I drove mine down to melb he really is that good.He does do mail order chips as well Link to comment https://www.sau.com.au/forums/topic/229546-my-r33-turbo-in-on-my-rb20-dont-know-where-should-go-next/#findComment-4040096 Share on other sites More sharing options...
TTT Posted July 28, 2008 Share Posted July 28, 2008 Are you telling me that there is no-one in Japan that can do a CHIP for a car/motor/ecu that's been around IN JAPAN for 19 years? Not saying DR-Drift is good, but he lives in Japan FFS.. we get cars come over here with MINES chips etc. why would he not do this instead of getting DR-DRIFT or toshi or cef11e to tune for a fuel we don't even have here?? Link to comment https://www.sau.com.au/forums/topic/229546-my-r33-turbo-in-on-my-rb20-dont-know-where-should-go-next/#findComment-4040273 Share on other sites More sharing options...
335 Posted July 28, 2008 Author Share Posted July 28, 2008 Are you telling me that there is no-one in Japan that can do a CHIP for a car/motor/ecu that's been around IN JAPAN for 19 years?Not saying DR-Drift is good, but he lives in Japan FFS.. we get cars come over here with MINES chips etc. why would he not do this instead of getting DR-DRIFT or toshi or cef11e to tune for a fuel we don't even have here?? There are places here, but I dont know where a lot are. Plus they charge crazy money here for a lot of this stuff. I try to put on as much stuff as possible getting help from friends. But none of my friends know how to tune. How can I contact DR. Drift? Link to comment https://www.sau.com.au/forums/topic/229546-my-r33-turbo-in-on-my-rb20-dont-know-where-should-go-next/#findComment-4041049 Share on other sites More sharing options...
Grunter Posted July 29, 2008 Share Posted July 29, 2008 Are you telling me that there is no-one in Japan that can do a CHIP for a car/motor/ecu that's been around IN JAPAN for 19 years?Not saying DR-Drift is good, but he lives in Japan FFS.. we get cars come over here with MINES chips etc. why would he not do this instead of getting DR-DRIFT or toshi or cef11e to tune for a fuel we don't even have here?? Fair enough I didn't read that he lives in Japan FFS! Link to comment https://www.sau.com.au/forums/topic/229546-my-r33-turbo-in-on-my-rb20-dont-know-where-should-go-next/#findComment-4044443 Share on other sites More sharing options...
