Hello
I have a R32 GTS-T. I put a R33 turbo on it. It has a HKS adjustable acuator. I have it set at .5 bar. Going to set it at .8 or .9. I have a catback exhaust, intake.
What else should I do next? I have a R34 SMIC that I haven't put on yet.
I want to get the most out of this turbo that I can. Should I get a GTR fuel pump or a Nismo 4L pump? Should I put in GTR injectors or Nismo ones or keep stock? Do I need a aftermarket computer now? Should I go with the down pipe/ front pipe? Do I have to tune if so?
Later, in the winter time, I will buy a friends TD06 but cant afford it right now. Later going to get Emanage, and FMIC.
I have read and read and I really don't know where I should go from here. There is a big improvement in response and speed just from having the R33 turbo on there.
Help!
I want to do next important upgrading!!! I live in Japan and the area where I live gets only about 30-32 degrees celcius in the summer on average.
Edited by 335
well i have a stock rb20 with rb25 turbo, 3" turbo back exhaust (no cat), bosch 910 pump with surge tank, 600x300 fmic, safc II, manual boost controller (turbo tech) & thats it.
gives a responsive 250hp atw, but larger turbo, injectors afm & nistune flash will be going on pretty soon.
Cool
Why the surge tank? Does the fmic give much lag? The reason I am going with the R34 smic is because I read on this forum that it is about 50% bigger than stock. So its shorter travel for the air to the turbo so hopefully not a lot of lag.
What kind of larger turbo are you putting on? What is a nistune flash? Why a safc II instead of a computer?
Thanks
I would put the exhaust and r34 smic before boosting. Its best to no not go past 14psi on stock r33 turbo otherwise it starts to get risky. But when u do boost, you should get a tune.
Thanks
I will finish the exhaust(downpipe, front pipe, better cat) after I get a computer. I will put the smic on within the next two weeks. Busy with work. I will not be able to buy a computer and tune for about 1 to 2 months due to having to use money for something else. Is this fine? I will make sure not to set it about 14 psi.
Cool
Thanks
yeah the surge tank is a bit of overkill but it & the pump were installed by the previous owner when the car had a different motor.
this setup is very responsive with sfa lag imo & i wouldnt run anything else but a decent fmic.
it has custom cooler pipes & the cold side pipe (after the cooler) is fairly short compared to some setups ive seen.
anyway i dont mind a bit of lag especially if you can run say 20psi & have a real good hit of power.
the safc was put on by a previous owner cause when he bought the car it had been bought back to pretty much stock. it was running autronics & hks turbo etc before he bought it.
the car is making reasonable power with its basic mods & a lot of that is probably due to the safc.
im going for a nistune flash instead of a new complete ecu cause they are only about 800 bux tuned & do the job i believe.
the turbo thats going on is a s/hand (6 months old) Apexi AX53B70 P-25, its a bit smaller than i probably would have liked but for $1000 for the complete apexi kit (turbo, dump, braided lines, etc) it was pretty hard to pass up.
cheers
Edited by norwest_rumbler
Hi mate I have headed down the same path as you when you do decide to
go down the path with a computer upgrade to handle all these mods.
I would higly recommend that you go n see Dr Drift for a reflash chip for
the std computer as this is what I have done and the results have been
unreal totally different car to drive shit loads more mid range and can
drive the car on the throttle more around the race track.This has been
the best mod I have done on the car so far,and a lot cheaper than a pfc.
Good luck with it
he lives in japan so are these reflash options really viable?
can he send them his ecu & they modify it & flash a generic tune to suit his mods?
i would have thought a live/real time tune was the only type worth having
Are you telling me that there is no-one in Japan that can do a CHIP for a car/motor/ecu that's been around IN JAPAN for 19 years?
Not saying DR-Drift is good, but he lives in Japan FFS.. we get cars come over here with MINES chips etc.
why would he not do this instead of getting DR-DRIFT or toshi or cef11e to tune for a fuel we don't even have here??
There are places here, but I dont know where a lot are. Plus they charge crazy money here for a lot of this stuff. I try to put on as much stuff as possible getting help from friends. But none of my friends know how to tune.
How can I contact DR. Drift?
Fair enough I didn't read that he lives in Japan FFS!
    • S2/3 GT-R is the same as S2 GTS-t The SRS airbags module in under the centre console. The S1/S1.5 GTS-t and S1 GT-R had the module built into the steering wheel. FWIW, I have a S3 GT-R wheel in my S2 GTS-t shit box. Same airbag plug, airbag light goes on then off, meaning all systems are go. S3 GT-R has red stitching, that's about it.
    • Dumb question, but why would it matter if the wheel came off a car with hicas or not?
    • Hey to anyone that reads this, long time lurker first time posting, sorry if it’s been answered before but I’ve been looking for nearly a year now for answers. ive got a 25det neo in an r32 that works awesome when it works (made 500whp on 21psi) but works 45% of the time, 1st issue there’s a harness that runs under the passengers side front fender that my tire keeps rubbing through and one wire seems to power the fuel pump even though I’ve done the relay “mod” some people like to call it, and when it does rub through it kills the car, yes next time I’m with the car I want to take the fender off and try tuck the harness well out of the way but I’d also like to try and by pass this mysterious wire as well lol, also wouldn’t mind getting power from the alternator as I’ve read it supplies the pump with 13v ? But no idea where to run the power wire too. 2nd issue, when replacing my fuel pump and fuel hanger I managed to break the factory fuel level sender leaving me with no fuel gauge, I’d like to buy the fpg fuel level sender for r32/s13 but the plug it comes with confuses me, I’ve got a detschwerks x1 fuel hanger which has light + pump - level + pump + and a ground, I’m no auto sparky but I’m wondering if I can cut the plug off the fuel level sender and wire the negative to the pump negative and wire the positive to the level positive to get a fuel gauge back ?🥴 3rd and final issue, the reason I want a fuel gauge is because whenever it’s below half a tank, it fuel starves like crazy and runs like a bag of shit even without doing a pull or sloshing the fuel round in the tank, I’d also like to fix this but have no idea what’s causing it, I’ve got a dw420 and a dead head fuel setup meaning the fuel is regulated before it gets to the engine, my only theory is that the return line is to close to the pickup on the pump and when it’s at half a tank the return line is causing the pump to cavitate enough to cause fuel pressure issues, that or the pump isn’t low enough in the tank which I would find strange considering I can’t find a single thing online about it, also if ya wondering how I figured out it happens at half a tank without a fuel gauge, I waited until it started happening and went and filled up and the car took exactly 30 litres every time I tested it, if ya managed to read through this mess I appreciate that and any recommendations , cheers
    • ChatGPT is trash and lies about things I would not expect it to lie about considering many things it's wrong about are very easily verified with google. The S3 R33 GTR shares its steering wheel with R33 GTSTs of the same production year. Part number is 48430-26U17. I'm guessing you have to get it from a car that came with HICAS though, the ER33 is 48430-26U18, but the HR33 diagrams note that part number is still leather vs 48430-26U13 which is not leather-wrapped. They all use the same airbags, so if you need another one you can get it off basically any same year R33 or Stagea.
    • I'm going to run hard lines front to back in the future. That should help dissipate a bit more heat. If not, a fuel cooler might be next
