Driveline:
RB20DET
RB25DET gearbox
OS Giken Twin plate & light weight flywheel
2-Way LSD
HKS T04e
HKS cast manifold
HKS 38mm external gate with screamer
Wolf 3D v4 ECU
Blitz stainless air filter
Custom stainless crossover & turbo outlet pipes
Walbro 500hp fuel pump
GTR injectors
GTR intercooler
Trust Type R BOV
3in turbo back exhaust with RSR cannon
Splitfire coil packs
Modified rad support housing triple core TR's radiator
Twin thermo's (tempreture controlled via ecu)
ARC oil cooler + Grex filter relocation
Sard header tank
Cusco oil breather
Suspension/Handling:
Seam welded
GET coilovers with camber tops(rare high quality Japanese units)
Tein castor rods
Cusco rear upper arms
Cusco rear swaybar
Rear traction rods
Welded rear strut brace
Non HICAS cradle
Alloy cradle bushes
Alloy steering spacer
5 stud conversion
Interior:
Red Fixed back seat
Side mount rail
Abarth leather wheel (better than Nardi)
Omori Oil pressure, Omori water temp, Greddy oil temp, Blitz boost gauges in custom dash panel
Greddy Profec-A EBC
Exterior:
Pearl blue paint
Missile front bar (missing lip)
Insurance DIANA skirts and rear bar
Yanack bonnet vent
Bolt-on flares smoothed over
Late model front/rear lights and grill
Stich Evolution 18x10 +18 front(+8mm spacers), 18x11 -1 rear
Falken Azenis ST115 235/40's & 245/40's with good tread
Other stuff:
Factory sunroof
Fully rebuilt tailshaft
Jap workshop & club stickers
Bad bits:
-Will be sold as a race only/parts car. I may include an original 15 yr import approval which the new owner can use at their discretion. For more info PM me
-Guards could do with some attention.
-Clutch isn't disengaging fully. Still drives and idles fine, hard to engage 3rd and 5th at high revs. This started happening straight after new engine was installed. Suspect snapped release pivot which is a cheap replacement.
-Needs new front tyre.
Only on basic tune atm. 220 rwhp on 9 psi. No where near turbo's efficiency.
Very unique vehicle. As far as I know the only Cefiro in Aus with Insurance skirts and/or rear bar. In saying that don't expect show quality body and paint, car is a pig. Have pics of car competeing in the Adavn Drift Meeting which is a qualifying round into D1. Over 25k spent on mods in Japan.
$8500
PM or CALL
0415291321
Sunshine Coast
https://www.sau.com.au/forums/topic/229567-cefiro-track-car/
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
