I looked but didn't really find anything useful so I will ask. I want to get oil pressure/water temp/boost gauges but when I fit them I would like them to sit beneath my head unit where the din pocket goes. Is this possible? If so, how can it be done? I reckon they would look mint there. Any other suggestions?
Cheers,
Evan
https://www.sau.com.au/forums/topic/229573-gauges-in-din-pocket-area/
been done plenty of times dude, might be a tight squeeze for 3 guages unless you allow it to take up both pockets although i think i have seen it done in the one pocket, you could try using some aluminum sheet and just cut the holes for the guages where you want them to sit, the fix the plate in place where the din pocket screws go
Hey,
Yeah it can be done pretty easy. You could get the Defi din Gauges or you can get the justjap gauges. Justjap do a package where you get 3 gauges (boost, oil temp, water temp) and a metal plate that will fit under your deck. There are also 3 different type of packages with different gauges. Cost $175 all up for the Justjap package or around $500 for the defi din gauges :thumbsup:
Just make sure you dont buy the din GTR gauges... i did that and then found out that i couldnt use them in my gts-t...lol
http://justjap.com/store/home.php?cat=267
Edited by R33Matt
Terrific, thanks everyone for your replies. I like the defi gauges a LOT but damn theyre expensive for 3 gauges... Any experience with the jjr gauges? Are they accurate? And it doesn't quite specify if they are electric gauges or mechanical. I don't really like the idea of hot oil and water lines going thru into the cabin of my car...
Cheers,
Evan
Yeah the JustJap gauges that come in the package are mechanical, but you could buy the metal plate for $20 and then buy the electric gauges seperate. They sell the electric gauges as well for $90 each. Ive used a Autogauge Boost Gauge in my R32 before and had no problems :thumbsup:
  • 3 weeks later...
hey mate
check this: scroll down for the interior pic
http://nissansilvia.com/forums/index.php?showtopic=269140
u will see i just got a 3 din c/f surround and passed all my gauges through there...
dont ask me where i got it from, a mate gave it to me so i guess try autobarn or just jap???
Does anyone know if that Defi DIN gauge set can actually replace the original gauges in the GTR?
Also does it come with a boost gauge? it doesn't say
The defi din consists of 1x Pressure and 2x Temperature.
So you connect the pressure to either boost or oil etc
