  • Replies 84
Posted Images
  Roy said:
Bin the 10cm housing. They make about the same peak power, but at 4,500rpm you will be losing 50-60rwkws :)
Id love to but $$$'s just dont see that happening anytime soon so will have to stick with it and see how it goes.
  URAS said:
Used this to try a quick theory i had regarding d-jetro and other rb engines so i fired one up on a R33 first then fiinally fitted it up into this R31.
Std Rb20
Rx7 injectors
Thai plenum
Trust TD06-l2 -20g (2 litre nirvana)
rb26 d jetro
277rwkw @1.2bar
408Nm@6100
Real nice car to drive, lots of usuable power and screams like crazy over 4500 and has phenomenaly strong mid and top... will interesting to see it lap winton this weekend,
I forgot to ask Trent/Wheezy, is the car running an EBC, the full L2 kit and what size waste gate spring???
Cheers Ben
  Wheezy said:
Standard Trust waste gate (42.5mm) with 0.7bar spring IIRC
Blitz ID3 (Dual Solenoid) EBC
Ah ok, my kit came with the Type R 47mm gate and i'll be running the 1.5bar spring but still contemplating if i should get an EBC or tune it with the turbotech first then borrow one to see if there are any gains to warrant the extra $$$'s
Im looking into other turbo options now as well :P
  RS500 said:
what turbo are you looking at?
Looking at viable options at them moment, would be great to get the L2 8cm but budget doesn't stretch that far at present but in no rush.
Want to match the turbo to the rest of the set up as best as possible so if that means waiting till i can afford to then so be it.
I too have the Type R gate (I have the pro L2 Kit), however I thought it was only 42ish mm in diameter....
I might check what the catalogue says tonight (and actually check the gate when i cbf)
grandmasterb : Spec R in the kit is 42.7mm, there is also a 51 and 61mm gate and some smaller ones. (Trust 2008 catalogue)
If you want a 1bar gate spring it can be ordered VIA an autobarn or GCG (if they will deal with you direct)....
If they are not in stock Im sure they wont take more than a month from Trust.
Raz: I think some cam gear and a slightly more aggressive tune could fetch 300 easily, but would be leaning on the engine. I would personally only do it for a dyno figure and pull the tune back again :P
Raz: I think some cam gear and a slightly more aggressive tune could fetch 300 easily, but would be leaning on the engine. I would personally only do it for a dyno figure and pull the tune back again :rofl:
Is that an Australian Trust catalogue Wheezy cause all the ones i've looked at online don't list the smallest (Type S) which is a 34mm, then there are Type R and C which are 47mm. I've just been using the GReddy US site so maybe its different???
I just ordered a new spring and gaskets from Japan as everyone i spoke to in Oz (including Autobarn) said they couldn't help me :starwars:
I still cant believe the numbers Trent was able to get out of your set with only 1.2bar and no cams/cam gears, i was only aiming for 240ish with my set up :devil:
I just ordered a new spring and gaskets from Japan as everyone i spoke to in Oz (including Autobarn) said they couldn't help me :(
I still cant believe the numbers Trent was able to get out of your set with only 1.2bar and no cams/cam gears, i was only aiming for 240ish with my set up :down:
Yup was an Aussie catalogue, they are sitting around all over my house LOL
You called the wrong autobarn's then :), I can tell you who to call in VIC, SA, and QLD (I'm not sure what state your in)
we just got rid of a heap of trust parts frigging cheap.....(autobarn as a whole) GCG is the new distributer.
FYI: Trust Type-R gates (and other types IIRC) come in various sizes.
  dmr said:
i'm happy to hear yet another great result from the RB20. these sorta threads keep me motivated to support the little ripper.
who gives a shit about lag down low when you have all hell breaking loose up top! :(
agreed!
ive got a 535HP rated low mount internal gate turbo which will be going on my rb20.
just gotta get the rest of the parts i need, afm & injectors.
