i was just curious to know if there is a way to calculate a "there abouts" quarter mile time using stats from a car... Power & weight.
i do understand it alot comes down to drivers ability traction and so forth... but lets scrap all the variables and leave it down to power and weight... every car has a limit as to how fast it could go down a quarter no matter who drives it.
is there some sort of equation that could calculate something like this?
https://www.sau.com.au/forums/topic/229586-calculating-quarter-mile-times/
I would say that computer program likes me and knows i wanna do a 10 lol
10.9 is fine with me :thumbsup: but i should be able to crack a 10 70
i'm running 12.5. easy :( obviously its not gonna be very accurate with only 2 inputs.
guilt toy. what did it spit out for you, compared to your actual time?
dude, it's challenging you !!!
hahahaa thats going by 2rismo's estimated weight in pounds he posted in my thread.
aparently im an 11.4... we will have to wait and see.
mine is pretty close to what times i am expecting so get some slicks and some drag radials and off you go :thumbsup:
pretty accurate...i put in my 3300lb to my 670whp and it says 9.91...my best is 9.95 but thats holding the car back by holding 3rd gear...so on a proper run id say a 9.9 flat is on the money.
put my new wheel hosepower in and weight 3300/900 and it says ill run a 8.9...yeehaa
Edited by DiRTgarage
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
