From our experience in Australia, the import system works as follows:
Cost of products + 15% (maximum) import duties + cost of shipping + 10% GST.
Note that for some parts such as engine management, there is 0% duties and 3% for turbos.
Although not a guarantee, we have found that small items under the value of AU$1000 are not generally inspected and pass through without the need to pay duties or GST.
I'm going to call who ever I need to call and find out regarding for sure regarding the engine management.
If so this means an AP Engineering Apexi PowerFC costs only $1498 inc. postage.
Can I use any Hand controller with the AP Engineering PowerFC or do I have to get one specifically to suit? I was under the impression that a hand controller is a hand controller.
I'm quite impressed with Greenline as 6 months ago I spoke to them and they responded very quickly with Professionalism.
As they did this time also. :)
Hi Joel, have you seen this on the greenline site?
"FC Commanders are suitable for A.P. Engineering and Power FC Pro units. "
Check it out for yourself
http://www.greenline.jp/catalogue/electron...ges/powerfc.php
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
