Hi Folks
I am a moderator on aus300zx.com, I thought the members here would be interested in the developments on this thread on our forum
http://www.aus300zx.com/forum/showthread.php?t=278134
If it can assist anyone who legitimately wants to fight an alleged speeding offence, all well and good :D
Cheers
Greg
gives us cliff notes. was he actually going that fast? if so, then why? if not why did the cops get a wrong reading?
No, he was not going that fast. There were 4 of us in the convoy.
You can't attack the reading or the officer, as all they have to do is produce certificates for the operator training and certification of accuracy for the device.
Despite the fact that you can still get a wrong reading, you just can't get anywhere in the court by using that reasoning.
This guy was targeted at 527 metres. Now, that's over 1/2 a kilometre (approximately 11 power poles in built up areas). They flew a LIDAR expert up from Victoria, and he himself admitted that the LIDAR beam diameter is wider and higher than the car at that distance.
The police office either lied or gave erroneous depictions of the days events like (no other traffic around), duh!! 4 Zs in convoy!! Plus the last day of a public holiday, the roads were packed. After giving evidence that no other cars were around, they played the tape of the day, and the magistrate says, "correct me if I'm wrong but that does sound like other cars are around".
Anyway, read through the thread on our site it'll all be there for your enjoyment.
In furtherance to your question regarding was he speeding, I can assure you that I would not have gone to all the trouble and expense (3 days off work) for a speedster.
Also, I doubt I'd get any support from our member-base if I was to publicly support illegal activities on our roads + I am in a position of responsibility within our organisation, so I have that aspect to consider also.
change your pic in your sig imo.. it shows your number plate lol
haha too late.
Once you swear on the bible, the next thing is to repeat your full name and address, so they got me anyway.
I'll be looking over my shoulder for a while.
Lucky my 300 doesn't stand out too much from others :D
Edited by PEX
No seriously, too many skylines on the road, we couldn't get over 60kmph :)
All jokes aside, I only posted here to help you guys, but I do appreciate your light-hearted banter :)
One day you'll all come up with something new and true about our cars.
When I bought the R33 to put alongside the Z, our members had nothing but praise.
Thanks for posting this info Greg, I believe that it is quite a significant case that Sean has won here and
that the ensuing result could possibly have far reaching ramifications for similar future or pending cases. :down:
Moral of the story:
- speed measurement equipment is not always accurate
- cops will lie to cover their arse
I would suggest it will have not other consequences apart from this matter being dismissed.
The devices are accurate when used in accordance with the guidelines. This sounds like it was not done right in some respects.
    • Yeah. I believe the fear of annealing the alloy and weakening it, Every online discussion has someone saying it's bad and potentially a risk when powder coating forged wheels.
    • I'm interested if anyone agrees with what you've said, and can give a good reason. Temperature of powder coating should be below any temperature you'd use to alter the wheel structure.  Powder coat typically 200 to 250. Annealing if that's what people are claiming would be occuring, starts at 300, and depending on the alloy, can need even up at 400+.   That's the only part I can think of that could cause an issue that people are believing it's from the rim losing hardness and becoming too soft.
    • Negative probe should be on the cars chassis. Positive on the wire.   Start as said above by unplugging everything (unplug the lights, and switches. Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch. If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.   Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.
    • Anyone know if it's a problem to powder coat forged alloy wheel centers (Rays/Volk GT-C). some say it's bad and can damage the alloy, some say it's not a problem.
