  • Replies 177
Nah I don't wanna drive yours to see the handling, just the 30DET (and do a burnout, jump out the door and leg it)
You don't know where I live right?
Paul, $1200
How bout I take you for a ride.. I mean.. drive :D
*shrug* stock for stock a 33 is a better prospect than a 32 but for minimal mods I believe a 32 is better (upgrade parts off later skylines to be used). For massive mods then it comes down to personal preference, I know I'd prefer to waste heaps of money on a 32gtst, but that's just me :starwars:
Unless its a GTR
32 loses in every department
This aint a war its a slaughter!
Lucky I have a 32R then... and im sure Bubba's 25/30 will pwn all.
We haz teh power & teh good looks, the 33 is the ugly fat girl with a nice personality.
No 33 vs. 32 war, its a slaughter :(
Indeed it shall! Went for a ride in an interesting car last night Tristran.. you would like :(
Can't spill too many details coz it's secret squirrel shit, but if you're up for a random spontaneous cruise this weekend, let me know :P
People who heavily modify there car like bubba i give respect
but were talkin 33 vs 32 without any drastic changes (eg engine conversions)
so yes 33 > 32 no debate! and.... 32 isnt hawt either, old interior, ghey ass bonnet bend (unless GTR) not to mention piss weak
Yeah! I gotz rezpekt y0! :P
I find the 32gtst to be a good starter as far as getting into modding cars go. Lots of cheap upgrades off the newer skylines such as 25 turbo, 33 brakes etc. Then you get into motors out of the newer skylines, I opted for a different route and built something that doesn't come standard in any car :D
Indeed it shall! Went for a ride in an interesting car last night Tristran.. you would like :laugh:
Can't spill too many details coz it's secret squirrel shit, but if you're up for a random spontaneous cruise this weekend, let me know :D
so mikes got the 32 going? ;)
I've had the R33 and R32 varients of the gtst and I think there's very little in it appart from taste in car looks. Both of my cars could run low 13's with the stock turbo.
have to admit, my mate has GTS4 RB20 stock with fmic + basics, had NO balls, he's just finished RB25 conversion i havent been in it as yet, but he says its BIG improvement. he's having partay tonight will have to snap a pic/drive before too many beers.
has the look of the R32 + RB25.. ftw
Ive also had both r33 and R32 GTST varients
exterior can come down to personal choice but interior the 33 is light years ahead
bolt on some mods and the rb20 will be left behind
the 33 gearbox will also handle much more abuse then a r32 gearbox
another thing is stock vs stock
r32 runs 10psi r33 runs 7psi?
R32 GTST 9-12k
R33 GTST 10-14k
R34 GT-T 23-25k
34 more torquey engine compared to the 33
stronger gearbox again
larger rear turbo housing then the 33 turbo (same as a 33 turbo compressor side but with a vg30 rear housing stamped as OP6)
slightly more top end power
R34 is awesome but for money you cant go past a 33 bang for buck
so mikes got the 32 going? :O
lol yeah, when I posted that it hadn't been tuned. Went for a ride on Sunday after it was tuned and man.. that thing is fkn FAST! (just ask Tristran.. he was trying to keep up and failed miserably :sick:)
You should come for a blat sometime, need to see how it goes against a real car :ban:
Edited by bubba
:O Its true... awesome car, poor Matty got left back on the horizon, at least i stayed in closeish lol
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
