Pratically im rebuilding my engine again due to my bearings that have given way.
My engine is a RB25DET and ive just purchased a RB26DETT engine intending to use its
block.
Should i go with the RB26DETT or stick to my RB25 cyl head?
Thing is, my head is prep with Tomei Cams, Valve Springs, Solid Lifter conversion, Adjust shims and
ive spent quite a sum on machining and time to get it running.
Ive a few questions below and would like some answers.
If i would use the RB25 cyl head, will it be a direct fit onto the RB26 block? Do i need to purchase a new cyl head gasket
to have it fit or just stick with the RB25?
What should i do with the VTC?
For the individual throttles, how do i make it fit into the RB25 cyl head?
OR
Should i just sell the damn RB25 cyl head and go with the RB26 and sort out all the fuss?
https://www.sau.com.au/forums/topic/229677-rb25det-to-rb26dett-conversion/
block.
OR
i own a rb25 and i soooo wish i just bought a rb26, it has better head, more choice of cams, slightly larger displacement, all a bunch of things i did that cost me more on my rb25 and came out to be more than a rb26
There are other issues with putting the 25 head on the 26 block.
No oil feed for the VCT on the the block (external feed required + modification to the head)
The RB26 uses larger head studs than the 25 does (26 studs wont fit the 25 head without modification and 25 studs wont screw into the block)
Cut your losses sell the 25 head and use the 26 head on the 26 block or buy another 25 block if you really want to use the head that badly.
Ill stick with the 26 head.
I really love the 26 from day one. But, financially at that point i couldnt afford a GTR.
Titan,
I dont understand the term u said on the VCT. Could u elaborate to me in detail
I will be building this engine myself. Dont want to be mislead or screw the 26.
Thanks!
yeah go with the 26 head, and sell the 25. What I would probably do is sell the 25 head and then invest the money into a rebuild on the 26 ie new stem seals, valve regrind, etc. Obviously if the head is recently rebuilt but you wouln't need to do this.
The 25 head on the 26 would involve modifying the head to use 26 head studs as already mentioned, and also running an external feed for the vvt, or you loose the vvt cam gear and also change cams. You mentioned you had tomei cams, are you still using the vvt cam gear then?
Also the shape of the water gallery on the 25 vvt head differs from the 26 block/head. It also needs slight modifying so that it has optimum flow. Then you need an adapter plate made up to use the 26 throttles which trust me, is a complete pain in the arse.
Edited by James_03
After a long consideration,
Im going with the 25 head and 26 bottom.
A lot of extensive modifications have to be done to keep the 25 head.
Its nothing much but just the time and effort spent on building the 25 head and the hectic measurements for the shims!
Its just not worth selling the 25 head.
Im planning to transfer all the 26 bottom parts to the 25 block.
Ive measured and i think it most probably fit without issues..
What 26 parts you going to use? Pistons/Rods/Crank in the 25 Block?
I converted my 25 head to solid operation and blocked off the vct.Its no longer an issue. I have no desire to change to a 26 anything. once modified there is stuff all difference between the 2 engines so whats the point. In my 18 months of linership The weakness of both engines would appear to be A. the 26 is hell on spun bearings. B. the 25 has a propensity to shit pistons.
I'll take B. A set of forgy's and the issue is no more. The 26 however would appear to continue to have the bearing gremlin wether rebuilt or not. Both great engines. Use what you have.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
