ok had a look and took some photo's there is T section in place near the throttle body with a black plastic tube attached i followed this thru the firewall into the cabin and is attached to a small computer with some jap writing on it under the dash on passenger side floor then it goes on thru behind the dash to my boost controller.
Do you think it is possible that i may be able to T into again inside the cabin for ease of installation or will it alter the reading the boost controller is getting?
The black tube you can see is also running thru the firewall with a small loom which is attached to a relay type thing you can see above the T piece on a metal bracket all of this is connected to the small black box under the carpet in the passenger footwell. Any and all assistance would be very much appreciated.
Edited by AndyD
No it hasnt got a screen i did take a photo of it and post it in one of my other threads it's an M's T-BAC3 just got 2 buttons and two dilas on it no screen. The vac line runs into a plain black box under the carpet and stops inside the box then a small cable comes out the other side and into the back of controller. Now if the pipe coming in is giving the controller boost pressures if i T piece it will the controller still get the correct reading sorry for the nubness very new to this.
Edited by AndyD
Im still a noob and had my stagea for over a year, heres my sugestion.. probably wrong. Cant see it being a problem as the box u have is only telling your boost controler what psi your running which is what your boost gauge will be doing. Trace out the larger hose to see where that goes as your rear nipple should not be used from factory. If it does something then it will be 3 things on the same line which might affect pressure
Ok done my plugs today checked all the coil packs 3 of them have been replaced and look practically brand new the other 3 are in excellent condition with not even a mark on them. Also done my boost gauge install i used the same line as the controller. Low boost was set on 5psi and high on 14psi which could explain it hitting r & r at 4000rpm tuned back down 10 psi. The plugs that were in it were iridium and varying gaps from 1.1 to nearly 1.6 but overall looked to be in half decent condition on the tips. Now after doing all of this i haven't reset the ecu or anything but fuel consumption has increased should i do a reset because of the different gaps that the iridiums had i replaced them with ngk 0.8mm in 6 heat range. Boost hits hard on 10 psi at 3000 and stays there solid with no spiking at all the controller seems to be doing it's job so i may keep it. Enigine check light came on again tonight so will do a consult tomorrow and maybe reset the ecu at the same time. Any thoughts
    • Welcome back, glad to hear life's wheel is turning in the right direction
    • Awesome pics Rezz, thanks for sharing them Another stop for my "need to do in Japan" list
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
