collecting parts for 26/30 conversion but need a couple of answers....
1) rb30 or rb26 head gasket?
2) looking for maximum torque and 7000rpm limit,any advantage to swapping std cams out for regrinds...if so what specs?
3) anyone used a copper head gasket,any dis/advantages?
4) worth 'O' ringing the block?
5) is the std nissan head gasket better than the cometic?
6) will the std RB30 balancer be ok under 7000rpm?
8) suggested single turbo for low end torque?
cheers guys
https://www.sau.com.au/forums/topic/229716-couple-of-rb2630-questions/
well i've been way off on alot things lately so make sure you get a second opinion, but i'll give you a start where i can
1. cant remember, someone told me you can use either, but i get a feeling you need the twin cam one - i know that wasnt much help (told you you'd need a second opinion)
2. for a street car, use standard cams. i think Ben (racepace) put standard cams back in his race car after having larger ones in there, thats saying something?
3. copper gaskets, not much first hand experience, but in theory - good because they conduct heat well, meaning less chance of heatspots forming on the ring of the gasket, bad because they can have issues with seepage
4. probly not for lower power levels, and i *think* thats mainly for copper gaskets???? someone confirm that for me
5. cometic is better (MLS gaskets)
6. is it in good condition? see how much you can get a new one for, its cheap insurance really
7. you cant count lol
8. GT35R
i had tought about mentioning GT30, i think cubes runs one? but its mixes results, some say it comes on too hard too early and just results in wheel spin, obviously it will yeild more low down torque, but its too much?
edit - just read a post of cubes saying its very linear.... and doesnt reult in wheel spin, GT30 might be an option
Edited by VB-
Im building a 30/25 neo at the moment, will be running .86 gt3076, i think it will be the ultimate street setup. No lag with over 300rwkw within easy reach
you don't reckon it will be like a like switch??
when are you expecting boost to start and be all in by rev wise?
300rwkw at what psi?
The opposite of a light switch, it should be a torque monster, making meaningful boost and torque from 2500. Full boost of about 16 psi should be in by below 3500.
we had a .82 gt30 on our old rb30det...think we pushed 365-370rwkws out of it with water/meth injection on shell 100 pulp. 8k redline and it was pulling all the way...didnt die out at all from memory. 256 8.5mm tomei poncams and greddy inlet, is what helped it maintain that power rise to redline...atleast thats what i think...maybe the water/meth injection too :wave:
cheers guys
1. Either way, more options available 26 way but.
2. Standard cams, go pon cams if anything.
3. Yes I have used them, prefer mls gaskets but less dicking around.
4. Only if your going copper gasket
5. No
6. Yes, ati to be safe but.
7. 35r as previously mentioned.
