tried wiring new numberplate lights on my r33, had the parker lights on and must have crossed the wires wrong, rear lights went out, the beeper inside the car from leaving the lights on stopped and dash lights went out...
i went to the fuses box and pulled the electric fuses to find it was ok. plugged it back in and the rear lights come back on, dash background lighting come back on and beeper come back on.
thought it was all good until i switched the lights off and they didnt go off, the light warning beeper didnt stop and background dash light still on.
its had me beat whats happining, can someone lead me in the right direction or have any ideas to whats happening
4drftn.
no havent got numberplate lights at the moment.
there was power getting to the numberplate light holdsters, i used a test light to check, but wouldnt light up the bulbs, even after changing the bulbs still nothing. so iv cut them off and attempted to wire another one i got from autobahn.
must have short something out, but didnt blow the fuse... from what iv tried sussing out the wire may have melted into another wire that has a current flow of power even with the ignition off.
so currently (temporarily) i have one of the fuses (electric) out. which disables the dash lights, rear lights when the headlights and/or parker lights are on, parker lights and warning beeper. done this temporarily so my battery doesnt go flat etc.
brake lights still operate once brake is pressed...
Hey mate. Just check to make sure that you didn't bump the fog light switch on the combination swtch. On my wifes 33 4door it has a switch near the end of the combo switch. If that makes any sense.
yes mate, i checked that shortly after it happened incase it was accidently bumped in confussion.
iv been told there could possibly be a relay behind the dash somewhere that could have burnt...
i may have to resort going to an auto electrician as im all out of ideas to what could be causing the drama
g'day mate. i'm an auto elect by trade and i don't think it could be a relay that has fused shut. for a relay to fuse shut you would have melted the wiring first and probably blown the fuse. if it is relayed it is negtive switch to the relay and sends a positive to the light. not the other way round. the original problem u had was just and earthing issue either on the bulb holder or in the wiring harness. the only way u can check if the harness is burnt is to remove the trim round the boot and remove the electrical tape. most melted wires only travel a short distance depending on how long the positive feed was to ground for. when u cut the wires did u notice if there was smoke signals or an electrical smell. if not u didn't melt the harness. hopefully this can help.
Edited by 116.hks
i currently have all boot trim removed from the car, i will take the tape off and have a check, it only sparked for a split second so hopefully the damage isnt far from the numberplate light location.
i didnt smell anything as i had the power off when i cut the 2 wires off. even after it sparked i didnt smell anything.
from what i have described, what are the chances of me having to replace the harness? or would there possibly be another solution or alternative to having the harness replaced?
from wat u have just said if you had the power off ( lights off) then i don't think you have done any damage to harness as such. if you don't mind me asking where are u located. i'm in redcliffe near brisbane. if you live round here i could meet u and check it out for ya. i'm just running out of ideas at the moment. wat u have done could not cause the harness to melt and join a positive to that wire.
that would be excellent only i live in TAS. :(
when i cut the wires everything was off, but when i went to wire it up/ test i turned the lights on and placed one of the wires on and nothing, then the other wire and nothing, then stuipidly i placed both on it which caused a spark.
i should have mentioned earlier... the light i tried wiring is a truck & trailer lamp (with no wiring), not an actuall numberplate light with an earth wire and a power wire.
NARVA truck & trailer lamp
P/No. 85874BL Marker Lamp (clear)
from my understanding (after it happen) these work by earthing or something along those lines...
picture in link - http://autoonecai.cart.net.au/details/528947.html
i guess i wont be calling round to help ya then :( . those lights are just a marker type light. yes they require pos and neg to work. the only thing that i may suggest at this stage is to disconnect the park/headlight switch at the steering column and see if the lights go off. if the don't you know it is definetly in the harness to the rear or possible to the front. if the lights go out then u might have a switch problem. if the lights stay on with the switch disconnected then trace the harness to the rear and disconnect any plug connectors and c if the lights go. it a process of elimination unfortunalty. c how u go with that if it gets to further involved u might have to visit your local auto elect. sorry mate. let us know how ya go.
wired up new (proper) numberplate lights tonight...
with the fuse out (lights off) i tested both wires with a test light. both wires were showing a negative (earth) current through them. im unsure if there is supposed to be an earth current through both wires??? -
- is that normal?
- or could it possibly be causing me the problem?
i put the fuse in (which sends power to the lights) and one had turned into a power which i imagine is normal.
then...
I wired the numberplate lights up... working.
now...
with the fuse still in (which means lights are on) i unplugged the connector plugs behind the tail lights. still stayed on.
i plan to remove the rear seats tomorrow, as i think there is a connector plug behind the seats.
you advised to start from the front and move towards the back. so i will remove steering column surround and start from the switch (indicator stalk).
I imagine the wiring also continues under the drivers side door strip/scuff plate.
Is this correct?
cheers
- is that normal?
then...
now...
Is this correct?
cheers
yeah mate that should be normal. i'll double check on me wifes 33 tomorrow on how they switch. when u say you unplugged the connectors behind the tailights did you disconnect each light and the front lights stayed on or you unplugged the rear lights completely and they stayed on? yeah if you start from the front to the back you should stumble across the problem. just remember to check the front parkers as well, to make sure they go off as well if you start unplugging the harness towards the rear. good luck. icon1.gif
Edited by 116.hks
    • I know this is an old thread but I have a particular attachment to the ENR34, so I don't think additional content hurts. For starters, I agree with everyone here in that the performance of a stock R34 GTR is a pretty low bar and one that you're going to spend a lot of money "matching". Now if you're willing to deviate from that template as your goal, you'll be much better off and enjoy the car much more. The engine in the NA R34s is a real kick in the nuts in terms of upgradability compared to previous generation NA cars. The NA heads on the RB2X NEOs have MUCH smaller intake port cross sections and are not compatible with any of the aftermarket forward-facing manifolds available for the RB25DET. This can be remedied with a RB25DET NEO head, but those are expensive relative to what they are. A full long-block from a turbo AWD Stagea is generally a better value and will run you about $4000 USD to get it to you. This will get you the stronger RB26DETT rods, as well. That would give you a base to build off of to be safe in the 400whp range. Not shooting for the moon, but if the stock R34 was your bar, this engine would buy you enough to be just North of stock GTR power. A forward facing manifold would allow for the easiest method toward using Bosch EV14 format injectors such as those from Injector Dynamics and FIC, to name a couple. People hate them because they're copies, but Greddy fakes can be had for around $300 USD. With what the fuel rail, regulator, injectors, and the rail adds, figure $2000 USD for the whole setup including the manifold. With the OEM brackets and a bit of trimming to the ends of the lower frame rails, the OEM intercooler mounting brackets can be used to mount an OEM GTR intercooler, or an aftermarket one made for a GTR. Those are handy vs a universale due to the angles that the end tanks have on them. Then your plumbing become super straightforward at that point despite having to cut a hole where the battery is an a matching one on the other side for the pipes. Battery can go to the trunk. I'd round up to a healthy $2000 USD here too (maybe even a tiny more) to allow for a nice aftermarket unit and some pipe fabrication. Or if you can find someone that's upgrading to something larger, the used market comes in clutch here for a decent savings. I won't even get into turbo sizing as that's something that would be for yourself to determine. HOWEVER, for the purposes of your stated goals, a Borg Warner 7064 with an internal wastegate would be a perfect spooler and would make stock GTR power easily. It would also bolt up to your OEM manifold (that would come with the DET you purchased a couple steps above) if it were ordered with a T3 flange. More with adequate fuel. If you can stick with the OEM exhaust manifold then expect to be in the whole about $6000 USD for decent turbo like the one suggested, a down pipe, new O2, and full exhaust to mate up, and upgrades to the integrated BOV in an EFR or a standalone BOV for a different turbo, as well as an aftermarket IWG (internal waste gate). Those last two are definitely optional and unnecessary. All of this stuff above does you no good without any way of tuning and or monitoring the engine. Bite the bullet on a standalone engine management solution. If your experience with wiring is limited, you're going to have to hand it off to someone else, though. Unfortunately, the adapter/patch harnesses available are typically made around the GTT which does not include AWD, and the GTR, which integrates into a lot of chassis features that aren't present in your wiring interface. So the ENR34 is the oddball. So you'll want to expand a bit on your selection and find an ECU that's capable of running the ATTESA pump also. I have a Link Thunder, but you don't need quite that much ECU to accommodate that. You WILL need someone with the know-how to tune it and code those features into whatever software it uses. And to wire it up. This will be your most significant expense. Call it $6000 USD with an ECU, an okay wiring job (no motorsport grade at this price), aftermarket triggers and R35 coils, and the time it takes to tune the ECU with added features (electronic boost control solenoid, MAP, IAT, the new triggers, and ATTESA) and don't be surprised if it's more if you want better work done. Grab a clutch made for any RB pull transmission R32/R33GTR made for the power handling capacity you're looking for. Budget $1500 USD for a new good one. That's about $20,000 USD for an engine you've upgraded yourself and had wired and tuned by someone else. That's no brakes (ENR34 brakes are pathetic), suspension (again, pathetic), or wheels and tires. So you're pretty spot on in terms of spending $30,000 USD extra on the car just to get it to perform a little better than a stock R34 GTR while looking like a bone stock ENR34 with some wheels and suspension mods. That doesn't include fluids, maintenance items, gaskets/seals, repairs needed or anything else discovered along the way. But you'll have a car you can take to the track and have fun without worrying as much about nicks and dings.
    • Okay so, please read this. car started and ran fine. got my tuned ecu by RSenthalpy, did a bunch of pulls to test it out and finally drive the car after half a year of it just sitting and idling at most. Everything was good, thing ran flawlessly and had so much power, didn't feel slower than a Prius anymore. Parked it back and turned it off.  Next day, I install an AFR and start the car. Didn't wire anything to the ecu. Just gauge.  Car started, but died out in about a minute. I figured it was cause my car was on a lift and the fuel was really low and old. I add 5 gallons of fuel, still cranks but no start. I remove all AFR wiring (tapped into double din acc and power wires but there was a nest of wiring there so I was worried I messed something up. tried to put it back to how it was prior to afr install.) Still cranks no start. Changed spark plugs with brand new ones Changed fuel pump with a new one (verified working) Did compression test , compression came back all at 150ish. All fuses are good, Relay seemed good but ill double check by switching similar relays around. Verified MAF is working - Ended up getting curious as to why fuel pump is not priming when ignition is on, so I cut the fuel pump ground and power and connected them directly to a portable jumper. I also disconnected fuel line to fuel rail to verify fuel is being sent. So with direct jumper power, the fuel pump turns on and shot gas everywhere through the fuel pipe that I had disconnected, so ny doing that, I verified no clogs in fuel lines or filter. - Tried starting the car with that jumper directly wired to power and ground, but car still did not start. I'm guessing its a CAS issue but im a little scared to check it without messing up timing or anything else since I actually dont understand how to check CAS lol. If anyone has any other suggestions or recommendations , please let me know.
    • Hi all. I am aware there is lots of discussions about jacking points, where to lift the car and what not. But as usual just a lot of "in my opinion" and nothing definitive, and everyone does it in a different way. I want to hear from some experienced people on which points on the car it's okay/safe/recommended to lift the car using a four point hoist/lift. I will attach some images of my underbody. Sills are largely okayish, the driver side jacking point is pretty mangled though and it looks like the underfloor is slightly pushed in too, but I might be wrong. In the German Skyline forum, the consensus is to use the sidemember chassis rails in the front and the rear subframe? bushing in the rear. I know the manual says to never use the sidemember for loading but lots of folk do it and it was definitely done on my car too as they are slightly bent too. Based on the images, what points do I use to not make the already present damage worse? I'd use wood or rubber blocks to spread the load across a bigger area of course. Driver side sidemember and jacking point mangled one) https://imgur.com/a/eKjzrJX Driver side rear jacking point https://imgur.com/a/W3DWF1P Passenger side sidemember and jacking point https://imgur.com/a/65UvIJe Passenger side rear jacking point https://imgur.com/a/h3k7j53 We can also see some underbody rust but so far it all looks somewhat treatable and nothing that requires a Yoshida style restoration.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
