  • 10 months later...
just bumping this up 9 months from the past but i now have the same problem, Happend this morning on my R33 gtst, it was very cold this morning and sound happend for about the first 5 mins after starting....
Question is to delta force or anyone else who solved their problem.... did the ticking sound come back when the oil got alittle older??? Mine was only changed 2k ago, had the car for a year and a half and first ive heard of the sound... only used elf semi synth but not sure on the grade of it....
I can still hear the lifters on a cold starts but much shorter ..only about 30 seconds or so and not so loud. Used to be a racket for about 3-4 mins before changing to thicker oil...
Just stick some 10W40 into it ..can't go wrong.
i'll see how the car goes thismorning on the cold start up,,,, maybe it was a once of, maybe all the oil was way at the bottom of the engine or something yesterday
  • 1 year later...
resurrecting this because I've been battling this annoying fkn noise for the past year or so again...cold startups only.
Just did some research and it appears that the most likely culprit is a dodgy timing belt idler pulley bearing ... that's exactly where the noise is coming from and looking at a couple of vids on youtube eg.
- that's exactly the type of noise and the 2-3 I read through, it was fixed with an idler/tensioner bearing change.
Now just wondering whether to redo timing belt/water pump as I'm not so certain these were done or done properly at least together with the pulley bearings or just do the bearings ... Does anyone know how much the tensioner and idler bearings cost ? Would the timing belt have to come off to change the 2 bearing ? I'm assuming it would ..in which case, probably not a bad idea to do the belt and water pump too hey
wait ..idler pulley is just behind the cam/cas cover right ???
edit: never mind .. that'd be the exhaust cam pulley ..hm why would I get noise from this area then ?!? it sounds EXACTLY like in the youtube vids I saw where they fixed it by replacing tensioner/idler bearings but those sit much lower ..just above and below water pump ??
    • Just don't use ChatGPT or any other artificial stupidity for the equivalent of googling. Their demonstrated inability to discriminate reality from hallucination should be enough to make them totally untrusted. LLMs don't know anything and cannot think to even the smallest extent. They are just predictors of the next word, and that should never be confused with capability.
    • I think, given the usage model described in the OP, I'd never ever experience the wonders of the 400kW upgrade. What I really need is boost from 2000rpm and probably no more than 260-270rwkW. But I suspect that the highflow is not actually the turbo for that purpose, so I may in fact need to get a G25 or 30 or something right sized and very spooly. We shall see after it is tuned. I've had to back the boost and boost ramp off to stop the thing from pinging since the highflow went on, so I've been almost living the NA life for 9 months now! Injectors are recently in hand. AFM is in hand. Dyno is fixed. Just need to clear a queue of f**king Supras out of the way (and probably fit my new gearbox). So....some time this year? Lol.
    • For what I gather is a Sunday/summer car....braided is fine. You're not going to be left without a vehicle and you have plenty of time for inspection/maintenance. Oof. I wouldn't use them that way. They can probably handle the temperature** but the internal corrugations means that their flow characteristics are a bit shit. Lots of extra friction and pressure loss. Makes them flow like the next pipe size down. ** They are stainless, and the stainless can usually be at least something like 304L, which is pretty good at higher temperatures (unlike 316L, which I would use for a wrt/corrosive environment, but not a particularly hot environment). But the welding needs to be top notch. And even then, because you usually need at least one cone-seat end on them (because you can twist the hose and do up both ends at the same time unless one of them is a union) they can be prone to coming loose with heat cycles.
    • I don't have the OEM oil feed lines though and the turbo-wraparound line is torn, only has water. My plan is to get replacements for these and just connect a braided line to there. And make sure it's leak free. Hoses like these are also sometimes used to connect external wastegates, so for an EGR I think you're good using them.
    • Alright I understand. The most likely case is probably gonna be that I just keep the OEM unit in the car as long as it works.
